Tangent Element problem
COW Forums : DaVinci Resolve
Von Thomas
on Aug 4, 2013 at 4:00:54 am
Ok, so I purchased a set of Tangent Elements panels, and now I'm having a bit of difficulty getting them to work with Resolve. I launched Tangent Synapse, all panels show up, I launch Resolve with the Element panel selected in preferences, but all I get is "synapse" in the panel displays.
OK, I just clicked reset in the Tangent Synapse window, now I have info in the display panels for Tk, Mf, Bt, but Kb is not lit up, nor working, any suggestions?
Von
Von Thomas
DIT / On-Set Dailies Colorist
Juan Salvo
Re: Tangent Element problem
on Aug 4, 2013 at 4:09:13 am
Are you starting resolve while synapse is running? I believe you need to have just resolve run, not resolve and synapse. You may need to reset the elements as your panels. Start resolve, select none for panel, quit resolve, stay out of synapse, then restart resolve, reselect the elements, quit resolve, then reopen resolve. Hopefully they work then.
color/post/workflow
http://JuanSalvo.com
Von Thomas
on Aug 4, 2013 at 5:06:34 pm
Thank you Juan. I've closed Synapse, 3 of the 4 panels are working in Resolve, Tk, Mf, Bt, but Kb, is not working. Kb works in REDCINE X, but not Resolve. Wonder what is needed.
Von
Von Thomas
Juan Salvo
on Aug 4, 2013 at 5:25:00 pm
you need to enter a function for it on the button panel.
color/post/workflow
Paul Provost
on Aug 5, 2013 at 7:31:40 pm
are you using using a good quality powered USB hub?
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
Twitter 4kfinish
David Berez
on Jan 29, 2014 at 9:23:54 pm
Von,
I'm experiencing the same problem you describe here. Did you get it resolved?
Thanks for any help you can share.
David
Post Office Editorial
postoffice@15elm.com
