Force conform to selected clip in media pool greyed out
COW Forums : DaVinci Resolve
chris larsen
on Jul 31, 2013 at 6:48:49 pm
I'm working on conforming a feature. The timeline is 2k with mostly red clips. I've got everything conformed properly except the VFX sequences. When I try to do a force conform with the proper clip selected I don't have the option. The clip settings match the timeline settings. The clip plays properly in the media source viewer. I'm working with a Full version of resolve 9.
brandon thomas
Re: Force conform to selected clip in media pool greyed out
on Jul 31, 2013 at 7:31:27 pm
Is the track locked?
You can add a track, and just lay the VFX shots above?
John Tissavary
on Aug 1, 2013 at 2:21:57 pm
Like Brandon mentioned, the track is most likely locked. You're either in the master timeline or you've imported an XML, which defaults all tracks to locked. If in master timeline you'll need to make a new timeline and work from that, as masters cannot be altered. If you're locked due to XML, just click the little lock icon at the left side of the timeline track to toggle on/off.
JT
John Tissavary | colorist | owner
The Post Collective
