Titan and GTX 690.
COW Forums : DaVinci Resolve
Rick Turners
Titan and GTX 690.
on Jun 24, 2013 at 3:07:04 am
Where can I get a 690 and/or Titan for Mac?
Do you just use the regular/pc version?
If so, does it need to be flashed or something?
Does it work with 10.6.8 or do I need to upgrade?
Ola Haldor Voll
Re: Titan and GTX 690.
on Jun 24, 2013 at 8:54:40 am
You'll need 10.8.4 in order to use the latest nVidia GPUs. There's no Mac version of these cards. There's a catch: no boot screen if you use the card for GUI.
I installed a Titan in my MP 2009, but I'm having some power issues. Not sure why.
During heavy load the Mac shuts down.
Rick Turners
on Jun 24, 2013 at 9:17:03 am
Hmph, I dont know if those issues would be worth it considering there is a mac version of the 680? I'm curious how different the cards perform in a single card config?
Rohit Gupta
on Jun 24, 2013 at 12:11:15 pm
The Titan won't work in a Mac Pro. There's not enough power. The best card for inside Mac Pro use is the 680 with 2x6-pin power connectors.
With a Cubix, you can use 4xGTX Titan.
Boris Tivchev
on Jun 24, 2013 at 6:25:20 pm
Hi Rohit,
The Titan should work with an external power supply such as http://www.newegg.com/Product/Product.aspx?Item=N82E16817104054
Am I right to asume that?
Boris
chris karcher
on Jun 24, 2013 at 9:32:04 pm
We tried both cards in a 5.1 macpro with cubix. With the Titan we can render out 5K RED to 4k masters @ about 14-20FPS with full res debayer and 3-4 nodes (qualifiers, power windows for sky tracking,etc)
The Titan edges out the 690 +quadro 4k. We're staying with the Titan.
On a side note:
Now If we can just solve the random black frame issue (it exists with any card we've tried) when rendering out +6min of 4k material. Workaround is to roundtrip XML to premiere, and re-render clips with errors (usually 1-3 per 5 min of mastering)
brandon thomas
on Jun 24, 2013 at 9:33:36 pm
Are you on the latest version of Resolve? Black flashes seemed to be fixed in 9.1.4
chris karcher
on Jun 25, 2013 at 8:52:17 pm
Yes, we updated to 9.1.4 but still get some flashes. It drove us a little crazy on a 9 minute 4K video we recently finished.
Juan Salvo
on Jun 25, 2013 at 9:26:48 pm
[chris karcher] "Yes, we updated to 9.1.4 but still get some flashes. It drove us a little crazy on a 9 minute 4K video we recently finished."
You're using Titan and 9.1.4? There are two know issues which result in random black frames.
1) was a bug with large LUTs in the node tree, on kepler GPU cards (680/690)
2) Is a card without enough RAM to store a large image (680 2GB, 690s)... this would tend to occur much less frequently.
Issue #1 was fixed with 9.1.4. Issue #2 should not affect the Titans. Are you sure you were processing on Titans and only with Titans? Did you enable the new "use GUI card for processing" function per chance?
color/post/workflow
http://JuanSalvo.com
chris karcher
on Jul 2, 2013 at 5:51:26 am
Thanks for the tip Juan. I'll check the prefs tomorrow AM
Eric Fiegehen
on Jul 2, 2013 at 6:55:31 pm
Hi Chris,
We would be interested to hear more about your comparison of GTX 690 vs GTX Titan, whenever you have time to contact us. We're testing both cards ourselves, but we're always interested in hearing more about the real-world experiences of customers such as yourself.
Eric Fiegehen
Director, Visualization & GPU Compute Solutions
Cubix Corporation
ericc@cubix.com
http://www.cubix.com
Christopher Johnson
on Jun 27, 2013 at 6:42:39 am
Yes, maybe not in a mac, but we have gotten multiple Titans and GTX 690s running no problem in our custom osx workstations.
Pepijn Klijs
on Jun 27, 2013 at 7:35:18 am
Custom osx workstation...
Sounds better then Hackintosh!
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl
