(not) Inverting key on outside node
COW Forums : DaVinci Resolve
Ben Edwards
on May 18, 2013 at 3:21:39 pm
Hi, on page 484 of the manual it talks about Outside Nodes and that they invert the key. At the top of the next page it then states
"If, instead of inverting the incoming key, you want to copy the existing key in order to perform another operation to the same isolated region, you can disable the key input’s Invert control."
Which is exactly what I want to do but I cant work out how open the key palette. I have searched the manual, this forum and google without luck. How do I do I get to the Key Palette and remove the invert?
Ben
Ben Edwards - Freelance Picture Editor
http://www.funkytwig.com
i5 550, Windows 7 / Mac Lion, Nvida 550 Ti, 8GB Mem
Margus Voll
Re: (not) Inverting key on outside node
on May 18, 2013 at 10:25:26 pm
Try to break alfa link from the initiating node?
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Vagelis Kasapakis
on May 21, 2013 at 3:22:36 pm
Hi Ben,
You can add a second outside node to invert the key
Vagelis
Ben Edwards
on May 21, 2013 at 5:23:48 pm
Margus,
This simply removes the clarifier (it is the dotted line you are referring to).
Vagelis,
Yes, that is the workaround I am using but not ideal.
Ben
