evga gtx 680 4gb, have someone test it in an early mac?
COW Forums : DaVinci Resolve
Evans Briceño
on May 12, 2013 at 10:39:09 pm
I saw on ebay that someone is selling a version of the gtx 680 flashed for mac with 4gbs.. since the official web site shows 2gb model only, my question is it worth it? to handle 4k footage.. is Davinci actually detecting those 4gbs?. Forums point out Adobe can't see it. just 2gbs. so Anyone has try it?
in other words... I feel more confidence buying the official mac version from nvidia, but it is tenting to boost the the machine with 4gbs to handle 2k and 4 k proyects with more nodes.
thanks in advance
Evans Briceño
BLUE films
Caracas, Venezuela.
VZLA. +584166352066 / +582122838114 / USA +1-718-673-3326
virtualevans@gmail.com / contacto@virtualevans.com / http://www.virtualevans.com
Peter Chamberlain
Re: vga gtx 680 4gb, have someone test it in an early mac?
on May 13, 2013 at 6:40:15 am
More GPU ram is better. The new config guide will suggest to get 4GB GPUs when u can. 2GB is ok.
Peter
Paul mitchell
on May 13, 2013 at 2:40:14 pm
hi Peter
how is more ram better, in what type of scenarios, only when working in 4K, how about just HD
when does the 4GB ram work better than the 2GB
thanks
Margus Voll
on May 13, 2013 at 5:15:59 pm
I bet it gives you more headroom
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Peter Chamberlain
on May 16, 2013 at 1:13:22 am
V10 offers temporal processing and OpenFx plugins and both are GPU ram intensive. We demoed at NAB iMacs with 2GB ram so that works for HD material but at some stage you will use all your GPU memory so if you can affords more, go for 4GB GPU ram.
Peter
Sam Petersson
on May 24, 2013 at 7:37:32 pm
Hi Peter,
Your last post in this thread addresses another question I posted recently on the Basics&Config board.
Would you recommend this 4GB version for a Mac Pro even if the PCIe link speed is only running at 1.0 (2.5 GT/s)?
Or would the Mac Edition of the 680, with only 2GB VRAM, running at PCIe 2.0 speeds (5.0 GT/s, as I understand) be better in this case?
Seems like this is an issue for all Mac Pro 3,1 owners running 10.8.3, as the PC versions of the GTX 6xx series will currently only run at PCIe 1.0 speeds in the Mac Pro 3,1.
Many thanks as always for your input.
