DaVinci Lite file splitting issue
COW Forums : DaVinci Resolve
Set Shuter
on May 10, 2013 at 10:08:24 pm
I am using DaVinci Resolve Lite 9 for mac and am trying to split a clip I was given for a short I am correcting. I go through the usual menu to select an EDL file and after it asks for the frames per second it just does nothing.
It was shot on a 5D mk 2 and was edited on AVID. The file is a quicktime DNxHD and my computer is a brand new iMac. I have attempted to install the codec package from AVID but it continues to fail.
Any help would be greatly appreciated!
Peter Chamberlain
Re: DaVinci Lite file splitting issue
on May 11, 2013 at 3:46:56 am
Resolve ships with the dnxhd support so u don't need a seperate codec install. If u manually place the big clip into the media pool, can you play it?
If so, then try to use the edl for a preconform workflow. Details in the manual.
Peter
Peter
Juan Morales
on May 11, 2013 at 9:34:46 am
The problem is that Davinci only works with the DNxHD codec as long as it's in a MXF container. It doens't recognize the codec when in a QuickTime MOV file...
Paul Provost
on May 11, 2013 at 6:59:03 pm
I thought 9.1.1 added dnxhd mov support
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
Set Shuter
on May 16, 2013 at 12:50:31 pm
Thank you it worked!
