this is the shift
COW Forums : DaVinci Resolve
keith mottram
this is the shift
on May 8, 2013 at 12:34:59 am
in color that is between what i can see and what is rendered. this is a problem for a color critical client. enclosed is grab showing render (pr422hq opened in qpx) to left of davinci window. has anyone had a shift like this? got a solution or output lut. it is driving me mad.
thanks in advance,
Keith
davinci 9.1.3, macpro 3,1, quadro 4000 + gtx285, etc
Juan Salvo
Re: this is the shift
on May 8, 2013 at 2:16:08 am
What are you using for external monitoring?
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
keith mottram
on May 8, 2013 at 10:39:14 am
Hi Juan,
Thanks for replying, i use a Panasonic 25" broadcast monitor via bm deck link. Color callibration in that sense is not the issue, I need to be able to match ref images and have those matched images stay matched on export. If I show a client that the images are matched on a broadcast then cannot give him or her a matched QuickTime I'm kind of screwed. Obviously there are always shifts going to h264 and my clients expect that, but these shifts aren't acceptable. Any advice greatly appreciated!
Keith
keith mottram
on May 8, 2013 at 1:57:22 pm
Okay after doing more tests it is just a quicktime player issue. The problem I have now is asking clients to view footage in something else mplayerX seems most accurate. Problem is if projects are ending up on the web and safari uses QT engine will the colours not be the wrong ones online too?
Keith
keith mottram
on May 8, 2013 at 3:41:30 pm
Update: The problem is solved (about 90%) by taking the footage in and out of symphony. QT7 is still closer than X but at least they are in the same ball park. God quicktime is a shitty piece of software architecture... Its a times like these where I seriously consider moving to a PC. then I use win8!
Margus Voll
on May 12, 2013 at 11:14:04 am
I use 10 bit RGB as output format on my mov files and skip prorez specially for web stuff.
Afterwards compression is done by adobe product and it seems consistent.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
