adding external matte from embedded alpha channel
COW Forums : DaVinci Resolve
Sherwin Akbarzadeh
on May 3, 2013 at 3:24:02 am
Hi guys,
Just running some tests for a upcoming grade. The test material has been composited and exported as RGB + Alpha. We want to grade the 2 layers separately in Resolve 9 Lite.
I thought that I would be able to pull an external matte in Resolve from the Alpha channel within the clip. But all of the documentation I have seen including Juan Salvo's helpful tutorial https://vimeo.com/49029693 uses a separate file to create this external matte.
Just trying to minimise the number of files/legwork we have to deal with. Is there a way to do it my way ?
Juan Salvo
Re: adding external matte from embedded alpha channel
on May 3, 2013 at 4:00:18 am
You can use after effects for example to render that alpha as a matte and then use it that way,
I believe Resolve 9.1 respects alpha channels in prores 4444 files for titles and the like.
Thanks for the kind words Sherwin, good luck.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Sherwin Akbarzadeh
on May 4, 2013 at 9:36:03 am
Thanks for confirming this Juan. All the best.
Sherwin Akbarzadeh
on May 8, 2013 at 4:25:57 am
Hmmm... Just a follow up question:
How can I control the matte and the inverse matte seperately?
I have added a serial node and added matte and am able to control the matte layer separately. I would like to be able to do the same for the inverse matte. At the moment my adjustments of node 1 (below) affect the entire image.
I have tried going back to media and adding the matte layer twice to a clip and then selecting straight for one and inverse for the other but this is not giving me an inverse matte.
Johnathan Throbins
on Jul 31, 2014 at 5:36:55 am
you just have to click the invert button on the key input tab
