a BMD AJA FSI JVC frame rate bit depth issue
COW Forums : DaVinci Resolve
michael stirling
on Apr 25, 2013 at 1:35:32 pm
Not sure if anyone else is running a system like this but I'd appreciate any thoughts anyone has on this problem.
My BMD Decklink Pro on my scopes PC will only show an input at 25p/50i and 60i but not 23.976 or 24 p or psf though the JVC will happily display at all settings. In the AJA miniConfig app it shows that the AJA is seeing the correct framerates and passing them through
However, if I remove the AJA from the chain and use the BMD extreme 3D HDMI out to the eeColor and extreme 3D SDI into the flanders then the scopes show inputs at all frame rates but the projector is stuck in 8bit (It greys out the deep color if HDMI comes from the extreme 3D).
My output setup is as follows:
Michael
