Titan v 690
COW Forums : DaVinci Resolve
Blase Theodore
Titan v 690
on Apr 23, 2013 at 2:11:52 am
Anyone put them up head to head in resolve?
Anyone know of a flashed bootable version?
Juan Salvo
Re: Titan v 690
on Apr 23, 2013 at 2:16:05 am
"Anyone put them up head to head in resolve?"
Yes. The Titan is about 50% faster than 680. It's about 85% as fast as a full 690. If you're using an expansion chassis doing high res work. Higher than 3K. Then the Titan is your best bet. But it doesn't work on the Mac. Works fine on windows and Linux though.
"Anyone know of a flashed bootable version?"
How do you mean?
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Blase Theodore
Re: Titan v 690
on Apr 23, 2013 at 2:27:23 am
If you don't mind me asking, how did you get those results? From what I've read they were designed for different purposes and the Titan should theoretically be faster in resolve. (But slower in 3d stuff.) It's design should theoretically be more geared to cuda stuff. Also it's a single chip vs the 690 dual chip, which resolve may like better. (Or may work better in a cubix.) So I was surprised by your results.
You actually tried both cards?
Flashing referred to putting Mac boot firmware on the card so it would load. But like you said, no drivers yet :(
Juan Salvo
Re: Titan v 690
on Apr 23, 2013 at 3:04:16 am
I've got several of both cards. They are different classes of chips, the Titans are GK110, 690s are GK104. The 690s are basically two slightly slower 680s sharing one board.
The advantage of the 690s is the combined processing of multiple GPUs, if you're running in a MacPro for example, and you put in one 690 and a GT120 or similar for GUI, using a full resolve license, you'd basically have the equivalent of 2/3rds of a cubix with three 680s available to you. Without having an external chassis.
The disadvantage is that the 690s only have 2GBs of RAM per GPU. This can become troublesome for larger image formats.
The Titans on the other hand are based on a different chip. Which as I mentioned doesn't have driver support on the Mac, but which has a significant processing improvement over the GK104, as exhibited on my Resolve linux system. Even better though is the 6GBs of RAM, which not only seems to improve performance, but also reliability with large images.
But like I said, in terms of performances, 1 Titan = ~1.5 GTX680s (plus lots of ram), where as 1 690 (meaning two seperate chips on the same board, with both chips working together) = ~1.8ish GTX680 (with a limited amount of RAM). On the Mac, once you get into expansion chassis the 690 looses it's advantage as you can only address 3 gpus on the Mac, and each 690 is two gpus. So with two 690s you loose half of one card. Titans on the other hand offer great performance and are only address as one GPU, so on systems that support it are ideal for an expansion chassis.
Blase Theodore
Re: Titan v 690
on Apr 23, 2013 at 3:39:55 am
Cool thanks Juan!
According to Netkas, 10.8.4 beta has Titan drivers. So thats nice.
John Hamlik
Re: Titan v 690
on Apr 23, 2013 at 3:46:59 am
Are you saying this is only using three GPU's on my Mac? GUI card is a Radeon 7950.
--John
Juan Salvo
Re: Titan v 690
on Apr 23, 2013 at 4:25:50 am
Are you running a hackintosh?
John Hamlik
Re: Titan v 690
on Apr 23, 2013 at 5:02:49 am
Standard MacPro.
--John
Juan Salvo
Re: Titan v 690
on Apr 23, 2013 at 5:10:04 am
Very interesting. :) There may have been a stealth update somewhere. Will look into this.
Margus Voll
Re: Titan v 690
on Apr 23, 2013 at 5:50:10 am
John enlighten us please :)
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Juan Salvo
Very Interesting
on Apr 23, 2013 at 9:20:14 pm
Fascinating. So unlike prior version of Mac OS X, 10.8.3 OS is supporting more than 4 video cards. I've booted(with giant caveat) with 5, but 6 cause my system to kernel panic on boot.
Prior version had a software limitation which only allowed the OS to address 4 cards. It was once suggested to me that this was related to a hardware restriction, that efi boot only had enough memory to address 4 cards. It seems that software limitation has been lifted. However the hardware limit still seems to exists. At least it does in my 2010 MacPro.
So I'm able to boot with 5 cards, but the system is basically unusable this way, it works in fits and starts. Seems to be choking on everything I do. I'll have to see if the 2012 version has addressed this in some way. Though regardless of whether it has or not this is good news for those using hackintosh, as they've never had the hardware restriction only an OS one.
John, are you actually using your box day-to-day with 4 cards? Do you find it stable? Seeing any crashes, kernel panics, freezes?
John Hamlik
Re: Very Interesting
on Apr 24, 2013 at 12:37:42 am
I use it everyday and have zero issues. EFI is an interesting tidbit as I am using non flashed PC cards, EVGA 4GB GTX 680's. This is why I use the Radeon 7950 for GUI, that way I get boot screen. I only use the 4 GTX 680's for CUDA. Performs way better than my Supermicro Maximus PC with Quadro K5000 and Tesla K20. I use it with After Effects and Premiere Pro as well.
--John
Paul Provost
on Apr 24, 2013 at 1:11:01 am
John, are you on resolve 9.1.3? I've got three of the same cards in a cubix on a 2012 Mac Pro and am now very curious about adding a fourth. Would come in handy when ofx support is added...
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
John Hamlik
on Apr 24, 2013 at 5:14:38 am
Yep, current version. He is a screenshot of after effects GPU panel as well...
Ronen Pestes
on May 3, 2013 at 8:09:49 am
John,
Do you use the 680 and the 7950 with a cubix or can they both live together in a MacPro?
I am looking to replace my old 120/285 combo and trying to see what are the best performance/cost at the moment.
Looking at slot requirement, I am not sure it leave space for BM card and any storage card.
Is my best bet is the 680 for GPU and 4000 (single slot) for GUI ?
Ronen
John Hamlik
on May 3, 2013 at 4:31:09 pm
Slot 1 - Radeon 7950
Slot 2 - Cubix Expander
Slot 3- Blackmagic Extreme 3D
Slot 4- Accelsior OWC 960GB
Cubix - (4) EVGA GTX 680 4GB
--John
Paul Provost
Re: Titan v 690
on Apr 23, 2013 at 4:28:16 am
What the what?! How is that possible?
Margus Voll
Re: Titan v 690
on Apr 23, 2013 at 9:41:16 am
I bet it is woodoo :D
Margus
Multibridge 2 Pro
Eric Hansen
Re: Titan v 690
on Apr 23, 2013 at 4:21:15 pm
isn't the GUI card usually listed in System Overview, along with GPUs and Rockets? i'm currently on a single card system, so i can't check.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
Paul Provost
Re: Titan v 690
on Apr 23, 2013 at 4:26:24 pm
GUI card does not show on list
Only processing cards
Jason Osterday
Re: Titan v 690
on Apr 23, 2013 at 5:54:37 pm
Wait, you can run a 690 in a mac pro with stock power? I thought the TDP for a 680 was the limit?
Also, 9.1.3 shows my GT120 as the GUI in the system overview. Then the 570s are listed separate (as GPUs).
Paul Provost
Re: Titan v 690
on Apr 23, 2013 at 6:19:46 pm
my resolve 9.1.3 system overview only shows GPUs (3 x GTX 680)
mac system report shows my radeon and 3 gtx though
Juan Salvo
Re: Titan v 690
on Apr 23, 2013 at 8:25:16 pm
Mac OS X does already support 4 GPUS. But not 5. At least that's how it used to be. Still looking into it.
Anish Prithviraj
Re: Titan v 690
on Apr 29, 2013 at 9:29:04 am
We are looking into this as well. We have managed to run a GUI GPU + 2 GTX 690s in a Cubix chassis as well as 5 GTX 680s (1 GUI + 4 GPUs in Cubix).
So far we have not run into any issues. But we are still performing tests and will let you know what we find.
Anish
Paul Provost
Re: Titan v 690
on Apr 29, 2013 at 3:48:19 pm
Great news Anish. Are you seeing performance improvement? And are you on a 2012 Mac Pro?
Juan Salvo
It works!
on Apr 29, 2013 at 5:41:34 pm
So based on comments from Anish and Rohit, I tried two 690s (4 processing GPUs) in a Cubix in 2010 MacPro again, this time doing an SMC reset, and jackpot! It seems to be working fine. All the cards show up and I'm getting playback, OS seems solid. This is pretty huge.
mel ristau
Re: Titan v 690
on Oct 24, 2013 at 5:31:28 pm
Juan,
Might you know if, with OS Mavericks 10.9, it is possible to run a Titan in a Mac Pro 5,1?
If yes, which product? Thanks!
Juan Salvo
Re: Titan v 690
on Oct 25, 2013 at 2:18:12 am
Not using mavericks. Likely won't be for some time to come.
http://theColourSpace.com
Blase Theodore
Re: Titan v 690
on Oct 25, 2013 at 4:05:32 pm
Juan,
I have been waiting for Mavericks because of its extended openCL support. (But also not switching yet.) Without it Programs like Premiere won't open. Are you using 10.9 drivers in your 10.85 build for Titan support?
Juan Salvo
Re: Titan v 690
on Oct 25, 2013 at 5:46:24 pm
Not using special drivers. Not using Titan on GUI.
Paul Jay
Re: Titan v 690
on Apr 23, 2013 at 8:09:06 pm
Titan will work in 10.8.4
andrew smith
Re: Titan v 690
on Apr 29, 2013 at 8:37:08 pm
Great news, thanks for sharing guys!
Curious as a fellow 2010 MacPro 12-core user, with or w/out a cubix4 what the 'highest' build specs will be moving forward?
Titan or 690 depending on whether one does or does not have a cubix?
Thanks again for the news and research everyone.
Juan Salvo
Re: Titan v 690
on Apr 29, 2013 at 9:02:13 pm
Presently the best performing config for Mac would probably be 4 GTX680 4GBs in a Cubix. 690s are two slightly slower 680s sharing a card.
Eric Hansen
Re: Titan v 690
on Apr 29, 2013 at 9:05:34 pm
curious to see how much of a hit the 2GB (per GPU) 690 would take on 4k footage vs the 680 cards with 4GB of RAM.
4 GPUs in only 2 slots is incredibly tempting though. or a 690 card in a Mac Pro with a separate GUI card. thats a lot of power without needing a Cubix
e
Eric Hansen
andrew smith
Re: Titan v 690
on Apr 30, 2013 at 2:45:36 am
What about the Titan card...theoretically speaking if its going to work in 10.8.4, wouldn't that yield better performance over the 680?
Wun Yung
Re: Titan v 690
on May 11, 2013 at 5:24:36 am
What I don't understand in all of this....
is how the Cubix Expander is not limited by the PCIE 2.0 bandwidth with 4 cards stuck in a Cubix Expander.
