How did I not know about this! My Tangent Wave just became 50% better!
COW Forums : DaVinci Resolve
andrew sableton
on Apr 22, 2013 at 11:41:18 pm
Eric Hansen
Re: How did I not know about this! My Tangent Wave just became 50% better!
on Apr 23, 2013 at 4:26:16 pm
theoretically, you should be able to use this app to remap any keyboard command to any controller, not just the Wave. i'm gonna give this a shot.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
andrew sableton
on Apr 23, 2013 at 6:23:42 pm
HI Eric,
I am using the free version which limits you to a certain number of functions or something....I only need a couple. It worked fine for me.....the only thing was, at least on my first try at it, that it seemed to ADD the function that I programmed in to the Wave, not change it out - so the buttons effectively did two things at once. If you carefully select which buttons to reprogram, this may not matter (eg the STOP button on the WAVE could be used and basically the fact that it STOPS AND TOGGLES the GRADES on and off is fine for me).
AS
Pepijn Klijs
on Apr 24, 2013 at 7:13:41 pm
I had the same issue of now having two command on one button. Is there a way to fix this?
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl
Danny Thompson
on May 23, 2013 at 6:20:06 pm
Controllermate does not remap controller functions, it just performs additional actions when buttons are triggered. Some controllers have native drivers for Controllermate but the Wave panel is not one of them, unfortunately.
