Conform Alexa 444 project in Final Cut
COW Forums : DaVinci Resolve
Mats Andersen
on Apr 11, 2013 at 5:16:20 pm
Working on this feature that for a number of reasons is most
convenient to online/conform using Final Cut Pro.
Raw footage is Prores 444, will export xml to get to Resolve.
Need to retime some of the footage, double the speed.
Is this safe to do in FCP ?
Can I be sure that I dont generate new frames if I adjust to 200% in FCP
and switch off frame blending before I send to Resolve ?
Juan Salvo
Re: Conform Alexa 444 project in Final Cut
on Apr 14, 2013 at 11:18:30 pm
Best is to remove speed effects and then recreate after grading. With the latest versions, speeds usually come across correctly, but not always.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Margus Voll
on Apr 15, 2013 at 6:01:55 am
And you do not get speed changes just linear speed adjust.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Mats Andersen
on Apr 15, 2013 at 8:12:38 pm
Ok, my solution was to export aaf files from Avid (with some speed adjust settings),
and then edit the change speed property in Resolve to something that can be
divided by my framerate (25 fps).
Does this make sense ?
