Playback from cache
COW Forums : DaVinci Resolve
Chris Tipton-King
Playback from cache
on Apr 9, 2013 at 1:45:32 am
OK, another basic question (sorry, again, googled and RTFM'd and didn't see an answer):
I turned on caching and played back my timeline so that now the clips display "100% cached," but I can't figure out how to get resolve to actually play back *from the cache* instead of just re-rendering when I play back. When I hit play, the cache % drops back to 0, the GPU bar goes up, and the disk starts writing again.
Thanks again!
Eric Hansen
Re: Playback from cache
on Apr 12, 2013 at 8:35:17 pm
hmm, not sure. mine just works.
the cache is DPX files. so if you're in HD, you'll need 250-300MB/s available. a single internal drive won't be able to do this. my system has a 4 drive internal RAID-0 for the cache.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
Chris Tipton-King
on Apr 13, 2013 at 4:27:50 am
I'm caching to a 450 MB/s SSD
Eric Hansen
on Apr 13, 2013 at 3:34:33 pm
if that SSD is just a single drive in a slot in the Mac Pro, it won't go that fast. did you try Blackmagic Disk Speed Test on it to see? i just tested a single Mercury Pro Extreme 6G in mine and i'm getting 130MB/s write and 250MB/s read
e
Eric Hansen
