how do I colortrace to a sequence in same project?
COW Forums : DaVinci Resolve
andrew sableton
on Apr 5, 2013 at 8:45:59 pm
I'm sure this is easy but I just can't see it.....
thx
AS
Eric Hansen
Re: how do I colortrace to a sequence in same project?
on Apr 5, 2013 at 9:21:39 pm
in the conform window, right click on the sequence you want to ADD grades to, click Colortrace
then it will ask what sequence you want to use as the source. select your current project and the source sequence in the drop down.
i'm hoping this is changed in Resolve 10 to make choosing and copying grades easier.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
andrew sableton
on Apr 5, 2013 at 9:26:57 pm
the problem is when I look in that window it gives me the option to select any project except my current one
jake blackstone
on Apr 7, 2013 at 3:51:04 am
Make a copy of a project and then copy grades from another timeline of your old project.
Joseph Owens
on Apr 5, 2013 at 9:27:53 pm
If the clip has the same identifiers, it should auto-link through the Master Timeline, unless you've got this function turned off.
If it doesn't, it is doubtful that ColorTrace will work automatically, and you will be into a manual trace.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
