Problem after reconnecting proxies to .R3d files
COW Forums : DaVinci Resolve
Greg Mezey
on Mar 26, 2013 at 6:43:00 am
I've been running into something that I've never come across before, hoping someone here has. I recently shot a project on a RED One MX. It was cut in FCP 7 with prores proxies, exported as EDL, and connected back to the .R3D files in Resolve. I've had no issues getting everything connected with this workflow. The problem arises when I try to change my metadata. When I make an adjustment, nothing changes in my image. The numbers change in the RAW tab, but the image and waveforms still look the same.
I've also tried reconnecting via offline sequence in Final Cut, tried XML straight from Final Cut, and XML through Red Cine X and back to Resolve. The metadata works as intended in Red Cine X, just not Resolve. Hopefully I'm just overlooking something simple. Any ideas?
