Full Res Debayer from F55 raw / low grade hardware
COW Forums : DaVinci Resolve
Nate Weaver
on Mar 16, 2013 at 11:58:57 pm
It appears running full version 9.1.1 on OpenCL hardware that I cannot get a full res debayer from F55 raw material. Per another post I had a month or two ago, my 1GB of video ram precludes it.
Is there anyway to force full res debayer via command line? Or, another idea, force via command line a CPU debayer?
The Sony raw viewer only allows DPX or OpenEXR output, so I'm having a devil of a time trying to get some high-quality tests done of the raw. The half-res debayer has aliasing and noise issues.
I've had enough of the Macbook and would jump into something better immediately, but the imminent Mac Pro update has me in a tough spot. Id like to know what's coming before I blow $2600 on an iMac!
Nate Weaver
Director/D.P., Los Angeles
http://www.nateweaver.net
Eric Hansen
Re: Full Res Debayer from F55 raw / low grade hardware
on Mar 17, 2013 at 4:39:34 pm
how about using the Sony software to create the DPX files, then play the DPX files back in Resolve? you'll need 250-300MB/s to play them back in realtime for HD-size DPX files. but if you're just looking at individual frame quality, that's probably fine.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
Eric Hansen
on Mar 17, 2013 at 4:42:03 pm
btw, we just rented an F55 for the week, and we can't turn on the raw recording. all the options are ghosted out. we have the AXS-R5 raw recorder and cards. any ideas?
thanks
e
Eric Hansen
Ned Soltz
on Mar 18, 2013 at 2:21:33 am
You must put the F55 in CineEI mode. That will activate the AXS-5 recorder.
Ned Soltz
Joseph Mastantuono
on Mar 18, 2013 at 11:57:44 pm
The Abel cinetech blog has a pretty comprehensive video about it...
Joseph Mastantuono
http://www.goodpost.net
Color Grading & Post Production Consulting
