Setting up my Color Correction Home Studio - Lightning
COW Forums : DaVinci Resolve
Pedro Saboya Burgos
on Mar 15, 2013 at 11:57:06 pm
So, I've already asked this forum about hardware, software and made my own home studio. Now I'm moving to a new place and decided to enhance it (since I've got now fairly good hardware in my room, which isn't a proper studio at all).
I decided to paint one of the walls in my new place grey, and light it the proper way... the thing is: what lightbulbs should I use? any 65K "daylight" bulb will do the job or is there any industry-standard specifics I should look for? If not, is there anything else I should look for when setting up my lights?
Hardware info, in case anyone needs it to answer properly:
AVID Artist Color interface
Sony PVM-1741 Oled Monitor (SDI In)
Blackmagic Express Pro (SDI out)
Imac I7
and that's it, still no proper scopes
Pedro Saboya Burgos
Assistant Video Editor
Video Editor
John Sellars
Re: Setting up my Color Correction Home Studio - Lightning
on Mar 16, 2013 at 4:00:27 am
http://www.cinemaquestinc.com/ideal_lumesb.htm#Standard
Or the Pro version if the wall is farther away. You are looking to get about 10% of the luminance of your monitor on the back wall (about 3fL)
http://www.sherwin-williams.com/homeowners/color/find-and-explore-colors/pa...
Most paint stores will match or cross reference this paint…
Jonathon Lee
on Mar 17, 2013 at 5:31:16 pm
I used the e-cinema paint... one thing to keep in mind is that it is an oil based paint... there are some threads about this. From what I understand this is the only thing that is close to being truly neutral. It's not cheap either. It's $125/gallon. The recommendation is 2 coats of primer and a coat of flat white before the application of the SP-50 paint. This will help stretch it out. I did the recommended preparation and am doing 2 coats of SP-50 on the front wall, a single coat on the side walls and flat black on the back wall.
http://www.ecinemasystems.com/products/monitor.php?product=12
Best,
Jonathon
