Davinci XML set to 24 instead of 23.976
COW Forums : DaVinci Resolve
Greg Penetrante
on Mar 15, 2013 at 3:19:04 pm
Hello,
I Am using 9.1.1 OS X.. I export a 1080p23.976 sequence using XML from Premiere. I grade, render out, and export fcp 7 XML from Davinci.
When I import back into Premiere CS6, the resulting time is set to 24 instead of 23.976fps. How do I get it back to 23.976 from Davinci?
Greg
Greg Penetrante
Re: Davinci XML set to 24 instead of 23.976
on Mar 15, 2013 at 3:38:33 pm
BTW I set the project/conform/time code setting all to 23.976. And the imported XML reads as 24 in Premiere...
Joseph Owens
on Mar 15, 2013 at 4:02:10 pm
This seems to be a bug in the XML re-write. Open the (Resolve) XML file (text editor) and check the status of NTSC (true or false) and change that value -- I think to "true" and you should get 23.98 when you open the XML back in Premiere. This was discussed on the Basics and Config forum.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Paul Provost
on Mar 15, 2013 at 5:35:46 pm
Another workaround is to set your sequence settings in resolve first to 23.98 and deselect "automatically set sequence settings " on XML import as it seems to me that's where it's happening. BMD have been silent on this bug. Maybe it's fixed in Resolve 10
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
Greg Penetrante
on Mar 17, 2013 at 11:35:46 pm
Thanks Joseph and Paul, for your solutions. They all worked. I must say that I enjoyed getting into the XML code and hacking around a bit ;-)
I definitely hope this is fixed in Davinci X - I Mean - 10.
Best regards,
-Greg
Paul Provost
on Mar 18, 2013 at 12:49:55 am
Davinci resolve X is autocolor only.
Joseph Owens
on Mar 18, 2013 at 6:23:19 pm
[Paul Provost] "Davinci resolve X is autocolor only."
LOLZ. Ouch.
jPo
Jackson Notier
on Jan 21, 2014 at 3:49:10 pm
I know this is kind of late but I have been having the same problem with individual clips, not an XML. I import a .cine file with 24fps, and I want to export 23.976 (don't ask me, it's the editor's required frame rate). Everything in Davinci is set to 23.976 until it is exported, but the resulting .mov is 24fps when opened in quicktime, or any editing software.
Jackson
Jackson Notier
Biwa Studio
Cinematographer - Motion Control Operator
