RGB values to replace color
COW Forums : DaVinci Resolve
Fred Lesage
on Mar 15, 2013 at 8:43:39 am
Hi all !
I'm quite new on resolve and I wonder about a point:
I would like to modify the color of a part of the image.
After an HSL process, I would like to give RGB values to the new color.
Is there a way to do that ?
For now, I can't see it...
Thanks a lot in advance.
Fred.
Dan Moran
Re: RGB values to replace color
on Mar 15, 2013 at 9:13:09 am
I wish it was that simple but you cant just type in an RGB value but if you right click on the viewer there is a toggle to display your RGB values. You can then point the cursor at the bit you want to change and then use the grading controls to move the image that direction.
Should get you the same end result-ish but slightly different method.
Dan Moran
Colourist
Smoke & Mirrors: London
http://www.danmorancolor.com/blog
Fred Lesage
on Mar 15, 2013 at 9:26:41 am
Thanks a lot Dan!
I'm aware of the "show picker rgb value" and I use it as I can:
the thing is I don't have a control surface, for now... (yes, I know... ;-))
