iMac NVIDIA GeForce GTX 680MX DaVinci Resolve performance is Amazing
COW Forums : DaVinci Resolve
Paul Jay
on Feb 27, 2013 at 1:40:53 pm
I'm lost for words. The performance is incredible. I haven't been able to make it dropped frames with 10 Nodes with blurs on ProRes.
Not really sure how this candle test works exactly, but i would like to test it.
I'm blown away by the performance of this iMac 27''
Margus Voll
Re: iMac NVIDIA GeForce GTX 680MX DaVinci Resolve performance is Amazing
on Feb 27, 2013 at 2:30:19 pm
what material and on what resolution ?
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Jason Osterday
on Feb 27, 2013 at 3:51:39 pm
What specs on that iMac?
The candle test should have a clip of a parrot (SD resolution) and you simply jump through the different versions to do anywhere from 04 to 64 blur nodes. Check it out and see what you get.
Paul Jay
on Feb 27, 2013 at 4:26:41 pm
I have found the parrot clip and the project.
But it has only 4 nodes with blurs.
What do you mean with jump through different version?
It's a 27'' iMac 3.4 Ghz i7 Quad Core - 1TB Fusion Drive - Nvidia GTX 680 MX 2GB - 32 GB RAM ( kingston)
Don't buy extra RAM at Apple. you can add 3th party.
Sascha Haber
on Feb 27, 2013 at 6:08:40 pm
When you right click the one thumbnail in the timeline you should bring up a menu where you can select 8 versions.
The noes will double every time and then Noise Reduction nodes will be added.
Switch to a version and let it play, then write down the FPS count and share with us.
I am very curious to see those numbers as my MacPro is dead now and Apple wants to replace it with an iMac.
A slice of color...
Resolve 9.1.1 OSX 10.8.2
Colorist / Aerial footage producer
http://vimeo.com/saschahaber
Margus Voll
on Feb 27, 2013 at 6:25:40 pm
What do you mean dead?
I have had soma anomalies now but after i replaced my os drive with ssd'd
Margus
Multibridge 2 Pro
Sascha Haber
on Feb 27, 2013 at 6:38:34 pm
I mean that it was in service three times now for the same reason and they acknowledge that they are unable to fix it.
They changed the main-board twice, the CPU one time and the last time they changed the logic board in the cinema display.
Who am I to tell them that it must the be the capacitors in the PSU...just because my TV had the exact same problem ;)
The computer does not wake up from sleep properly and I have to shut it down...all work is lost.
It also needs two boot attempts every single time.
Anyway, because the MacPro is officially not on sale anymore in Europe there are talks about offering me an iMac instead.
So I would like to see the numbers of the Standard Candle test if possible.
A slice of color...
Margus Voll
on Feb 27, 2013 at 6:43:23 pm
Yes please. I would also like to know.
Margus
Multibridge 2 Pro
mikee carpinter
on Mar 18, 2013 at 9:28:47 am
Candle test with New IMAC 2013
Processor 3.4 GHz Intel Core i7
Memory 16 GB 1600 MHz DDR3
Graphics NVIDIA GeForce GTX 680MX 2048 MB
Software OS X 10.8.2
V01 04 blur nodes 24 fps
V02 08 blur nodes 20 fps
V03 16 blur nodes 10 fps
V04 32 blur nodes 5 fps
V05 64 blur nodes 3.5 fps
V06 01 NR 2 nodes 7.5 fps
V07 03 NR 2 nodes 3 fps
V08 06 NR 2 nodes 1.5 fps
Paul Jay
on Feb 27, 2013 at 4:22:42 pm
ProRes 422 1920x1080 25fps
I've tested BMC RAW footage as well.
I get full playback with 5 blur nodes......On an iMac.
Sweet.
Margus Voll
on Feb 27, 2013 at 4:38:31 pm
Really good option for home small indy stuff then
Margus
Multibridge 2 Pro
Paul Jay
on Feb 27, 2013 at 5:09:06 pm
Indeed. Hook up a Thunderbolt Ultrastudio Express for SDI and HDMI monitoring and you're good to go.
andrew sableton
on Feb 28, 2013 at 12:13:14 am
Would love to hear what happens when you really push this system to the limits..... 2k and even 4k material...
I'm not expecting realtime playback with multiple blur nodes but wondering if it is usuable or becomes overwhelmingly laggy, beachballs etc....
S
Margus Voll
on Feb 28, 2013 at 6:01:53 am
4k seem pushing it already on paper
Margus
Multibridge 2 Pro
Rick Lang
on Feb 28, 2013 at 3:07:18 pm
[Paul Jay] "ProRes 422 1920x1080 25fps
I get full playback with 5 blur nodes......On an iMac."
Nice. Was that ProRes 422 (HQ)?
Rick Lang
iMac 27” 2.8GHz i7 16GB
Guillem Ventura
on Feb 28, 2013 at 6:35:02 pm
We're about to purchase one, but Apple asks for 6 weeks.
Any one having good experiences with Hackinstoshs?
Please post the candle or other tests so we can all compare!
By the way, our 2011 iMac w/6970 does perform decently. Not able to face a propper MacPro but fine for work without a client (and no CUDA!)
http://www.malgeniofilms.com
bob kimberly
on May 13, 2013 at 8:23:19 pm
just got mine...3.2 i5 and i'm totally converted....even my old tower from 2 years ago struggled with more than 2 nodes but his thing just flies through media...i used to do the rendering in pro res 1920X1080 and let it run overnight but now by the time i've made a coffee this thing is done! never thought i'd say this but WOW......if i could just resize the windows now i would be in colorist heaven...
Didier Martinez
on Dec 13, 2013 at 8:05:51 am
A question for iMac 27 (2013) users ; is there any overheat issue on it using resolve ?
