Your opinion on going from SD to HD
COW Forums : DaVinci Resolve
Tobias Heilmann
on Feb 25, 2013 at 9:23:20 pm
Hello everyone,
We are in the process of preparing the remastering of a film originally shot on Digital Betacam in the PAL format.
We want to recreate titles, Graphics, VFX, etc. in 1080i25 and also regrade the film using Resolve.
How would you go about up-resing from SD to HD? Would you use Resolve (grade and then output in HD)? Or would you use a different tool all together to do the upconversion? We are really looking for the best possible result, money not necessarily being the issue.
Thanks in advance for your input,
Tobias
In Touch Media Entertainment
Munich, Germany
Joseph Owens
Re: Your opinion on going from SD to HD
on Feb 26, 2013 at 1:41:07 am
resolve's bilinear uprez is generally pretty good. It would be worth the effort though to try a hardware conversion, Teranex an obvious candidate, but also a play-through and capture (if you have more than one system) using a Kona or Decklink, which are also surprisingly good.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Tobias Heilmann
on Feb 26, 2013 at 7:10:59 am
Thank you!
If am grading and resizing in the same pass (on the same timeline), will Resolve first resize the image and then do its node calculations based on the new (high res) image, or will it do the node-work and then resize that?
Yes, Teranex I contemplated as well. We have both a Kona3 and an BMD Decklink 3D Extreme to try this with, also.
Munich, Germany
Joseph Mastantuono
on Feb 26, 2013 at 3:08:14 pm
Resolve's scaling filter is very good, except I'm not crazy about its results with interlaced material. I'm much happier with it going from 720p up or resizing. I use a secret sauce mixing different software packages, depending on the footage when I have the time.
If you can rent/use one teranex is the way to go.
If you're strapped for time and cash, kona3 isn't bad.
Back in the day I really liked optical flow stung in shake and compressor but you had to be careful about artifacts.
Joseph Mastantuono
http://www.goodpost.net
Color Grading & Post Production Consulting
Robert Houllahan
on Feb 27, 2013 at 6:16:38 am
Get a Teranex, hands down the best conversion for the $ especially now that a 2D BMD Teranex is less than $2k and has thunderbolt capture. You can also control sharpening and NR a bit with the box and the processing is better than the Kona or most software scaling that I have seen.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.com
MAHC-PRO 6-Core 2X GTX580 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Tobias Heilmann
on Feb 27, 2013 at 11:10:10 am
Thank you all... ok, so I am getting the tendency towards Teranex - especially at that price it's a very attractive option.
However, I am wondering, is that the state-of-the-art? The top of the line? Or are you all referring to Teranex because of the obvious and undeniable value for the money ?
Munich, Germany
Robert Houllahan
on Feb 27, 2013 at 9:12:25 pm
Honestly I thin the new Teranex has to be close to "SOTA" I was curious if the BMD version was a watered down version of the VC-100 but I got one anyway and could not be happier with the conversions it does and I know someone with an insert shop who uses one for Broadcast conversions all the time.
Maybe a Snell would be 1% better? I don't know but the current Teranex is quite a bargain, especially for the price.
_Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
Tobias Heilmann
on Feb 27, 2013 at 9:49:48 pm
Thank you for the feedback... so Teranex it is.
Munich, Germany
Frank Gothmann
on Mar 1, 2013 at 8:05:54 pm
The vc100 does a decent but not fantastic job converting fields based formats. With slow frame rates it's pretty bad. 24 to 25 and vice versa is pretty much unusable for higher end needs. As far as scaling is concerned, it's quite good (better than Kona and BMD) but, again, if you want the best upscale quality you can possibly get it's either a Snell Alchemist or Archangel.
"You also agree that you will not use these products for... the development, design, manufacture or production of nuclear, missiles, or chemical or biological weapons."
iTunes End User Licence Agreement
Juan Salvo
on Feb 28, 2013 at 2:21:43 am
I'd say snell a good deal more than 1% better, motion compensation is a big deal, but for the price the teranex is hard to beat.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Tobias Heilmann
on Mar 2, 2013 at 3:08:40 pm
I hear you, I would however still be interested in finding out the answer to my previous Resolve question here:
!If am grading and resizing in the same pass (on the same timeline), will Resolve first resize the image and then do its node calculations based on the new (high res) image, or will it do the node-work and then resize that?"
Anyone know?
Munich, Germany
Juan Salvo
on Mar 2, 2013 at 7:50:32 pm
Resizing is done on input. First.
Tobias Heilmann
on Mar 2, 2013 at 8:16:48 pm
Thank you
Munich, Germany
Ernest Savage
on Nov 18, 2013 at 6:00:35 am
I'm about to through the same process you did with upconverting SD to HD, using resolve to color. How did it work out for you? Did resolve use the upconverted image to color instead of the SD image. How was the Teranex?
Tobias Heilmann-Schuricht
on Nov 18, 2013 at 6:19:19 am
Hi Ernest,
We postponed the project and I did not get to test the process.
Best,
Tobias
In Touch Media GmbH
Germany
Ernest Savage
on Nov 18, 2013 at 7:39:29 am
Hello, I'm about to do a similar project: SD to HD up convert, color in resolve. So I was also wondering what the best workflow is. I have a Teranex box and was going to upconvert at the end, after grading, but I wanted to view the images in HD as I colored. So you said Resolve upconverts on input, what does that mean, through a node? Or does it actually change the media from SD to HD when the media is imported? I'm also doing noise reduction with neat video when I export the media back to FCP7.
Thanks in advance.
Jef Huey
on Jan 11, 2015 at 4:00:20 am
I realize this is an old thread. I have tested this workflow and seem to find that Resolve does NOT handle pixel aspect ration conversion correctly going from SD to HD or HD to SD. It seems to in the timeline but renders are incorrect when taken to a different tool.
I would test this carefully before committing to Resolve for any conversions between differing PAR.
Jef
on Jan 19, 2015 at 5:54:46 pm
I would be interested in knowing more about this evaluation.
Is this a subjective opinion/oberservation, meaning, you don't like the way it looks? (which would be totally fine)
Or did you subject the uprez footage to some sort of technical evaluation? If so, I'd be interested to learn how to recognize a good uprezing job.
Tobias
In Touch Media GmbH
Germany
Jef Huey
on Jan 19, 2015 at 6:45:45 pm
We tried to be as objective as possible. We compared the Resolve conversions from HD to SD and SD to HD with hardware conversions of the same material. By hardware I mean both up and down converts using the built in convertors of Sony VTRs. We used the hardware conversions of the AJA Kona 3 cards and we used the Snell & Wilcox Alchemist. All files were imported into several NLEs to see how they were interpreted.
We liked the "look" of the Resolve conversions well enough. It was the purely technical issues we found unacceptable. Pixel aspect ratio was wrong in both directions. Plus - and as this was awhile ago so I may be wrong on this - I believe we found that field order was not being dealt with correctly in the conversions.
We reported these issues to Blackmagic. I have not retested with v11 of Resolve. Just have not had the time.
Jef
