Slowmotion in resolve
COW Forums : DaVinci Resolve
Daniel Albers
on Feb 11, 2013 at 9:23:26 pm
So I am importing an XML file into Resolve.
Everything works fine except the clips i slowed down in premiere..
It simply doesn't load them.
Is it just not possible or am i doing something wrong?
Kind regards
-EDIT
Im working in 50Fps.. dont know if this is what causes the problem?
Juan Salvo
Re: Slowmotion in resolve
on Feb 12, 2013 at 1:31:00 am
Welcome to prp XML. Run the XML through fcp to clean up. Or better yet: remove the speed effect in prp, round trip to resolve and then add the effect back in.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Daniel Albers
on Feb 12, 2013 at 9:48:51 am
Thanks for the answer.
I am running in premiere pro, just to clear things up.
I was just hoping i wouldn't have to delete any effects but i suppose davinci simply doesn't handle it?
Juan Salvo
on Feb 12, 2013 at 2:25:12 pm
It's not that resolve doesn't handle it's the prp doesn't properly explain it in the XML. Speed changes coming from fcp7 tend to work ok. But not from prp. That's why I said to take the XML through fcp7.
Cris Cazor
on Jan 14, 2014 at 2:01:14 am
Hi Juan,
So, would it be easier if I exported the XML at 100% speed from PPro to fcp and then on fcp do the slomo?, then export another xml and open on resolve?
