Resolve 9.1.1 crashing on source render
COW Forums : DaVinci Resolve
Alex Frankland
on Feb 10, 2013 at 6:35:44 pm
Just been rendering in source mode in Resolve 9.1.1 and it always seems to crash without an error report. If I were to render clip by clip it all seems to be ok. Any pointers?
- Rendering mixed files from an FCPX XML 1.2 on one timeline.. R3D, Prores etc.
- Resolve 9.1.1
- OSX 10.7.5
- CUDA Driver 5.0.36
- Quadro 4000 (GPU)
- Radeon HD 5770 (GUI)
Thanks.
8-core, OSX 10.7.5, 16GB
RAID5 4TB,
Radeon HD 5770, Quadro 4000
DeckLink HD Extreme 3D
JVC DT-V24G1
Resolve 9.1.1 + Wave
Peter Chamberlain
Re: Resolve 9.1.1 crashing on source render
on Feb 11, 2013 at 2:48:38 am
Which format and resolution are you rendering to?
Peter
Alex Frankland
Re: solve 9.1.1 crashing on source render
on Feb 11, 2013 at 3:12:12 am
Hi Peter, I'll be rendering for prores4444 at 1080.
RAID5 4TB,
JVC DT-V24G1
Joseph Owens
on Feb 11, 2013 at 7:14:37 pm
[Alex Frankland] " it always seems to crash without an error report."
How does it crash? Does it freeze up or exit?
One thing to check is your file names. If there are any HTML or directory/path characters, it will cause problems similar to what you are describing.
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
John Sellars
on Feb 11, 2013 at 8:18:45 pm
http://forums.creativecow.net/thread/277/20919
Also check to make sure there are no spaces (%) in the filenames.
Alex Frankland
on Feb 11, 2013 at 9:06:36 pm
[John Sellars] "Also check to make sure there are no spaces (%) in the filenames."
There doesn't seem to be any spaces in any of the file names.
RAID5 4TB,
JVC DT-V24G1
Juan Salvo
on Feb 12, 2013 at 1:29:26 am
Do you have any "/ <>~%^*+=}{][/€£¥•@"' in the file names? Do you have a slug clip in the sequence?
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Alex Frankland
on Feb 12, 2013 at 4:11:03 am
[Juan Salvo] "Do you have any "/ <>~%^*+=}{][/€£¥•@"' in the file names? Do you have a slug clip in the sequence?"
I had a problem file on my timeline that resolve didn't seem to like from the XML. Therefore I disabled it and replaced it with another file on the track above. I suppose I should completely delete the problem file?
Ps. Big fan of your coloristos podcasts :)
RAID5 4TB,
JVC DT-V24G1
Juan Salvo
on Feb 12, 2013 at 4:43:37 am
Yes, remove the clip from your sequence.
Glad you like the podcast. :)
Alex Frankland
on Feb 11, 2013 at 9:02:26 pm
[Joseph Owens] "How does it crash? Does it freeze up or exit?"
Resolve just completely exits. No freezing whatsoever. There also doesn't seem to be any HTML or directory/path characters etc. What's strange is that rendering as a single clip seems fine. The problem is in source mode.
RAID5 4TB,
JVC DT-V24G1
