Premiere Pro merged clips XML to Resolve 9
COW Forums : DaVinci Resolve
Daniel Neutzsky-Wulff
on Feb 10, 2013 at 3:09:51 pm
I just completed the edit on a documentary in Premiere Pro CS6.
The footage was shot with a 5D MKIII and I've edited the files in it's native H264 format in Premiere Pro. The audio was recorded seperately and then merged together, so they would act as a master clip in Premiere Pro.
Now, the time has come to colorgrade the project. I've cleaned up the sequence and broken them into 4 different parts lasting about 10-15 minutes each. All of the video is on one single track.
When I export an XML from Premiere Pro and import it into Resolve 9, only one clips shows up for some reason and I really can't figure out why. AAF export from Premiere Pro doesn't work either.
Any ideas?
Best regards,
Daniel
Re: Premiere Pro merged clips XML to Resolve 9
on Feb 11, 2013 at 11:19:55 am
Help?
on Feb 11, 2013 at 12:26:59 pm
If I can't get an XML working I will have to export a self-contained movie and use scene detection in Resolve.
What format should I export to from Premiere Pro? I am on a PC running Windows 8. All of the footage is native H264 files from a 5D MKIII.
Final delivery is for TV.
Chad Terpstra
on Jan 22, 2014 at 5:23:45 pm
I just ran into this with Resolve 10 and Premiere Pro CC. Apparently "Merged Clips" still don't jive with XML's or AAF's. Anyone care to confirm?
