Flashing colors in my renders....
COW Forums : DaVinci Resolve
Jan Gul
on Jan 28, 2013 at 8:47:38 pm
I just rendered out from Resolve Lite. I started with DPX files, made color corrections and I have exported out to ProRes422 and for some reason there are colors randomly flashing in the white areas. Has anyone else had this problem?
Jan
Lorne Wright
Re: Flashing colors in my renders....
on Jan 29, 2013 at 1:15:17 am
I've seen that when using a soft clip in Resolve lite. May also be due to only having a single graphics card in your system, but was never able to test
Cheers,
Lorne Wright
Finale Editworks
http://www.finale.tv
Rohit Gupta
on Jan 29, 2013 at 6:20:42 am
If you are on OSX 10.7.5, and if you have a ATI card, this is a known OpenCL bug in the ATI driver. The fix is to upgrade to OSX 10.8.2.
Michael Novello
on Jan 30, 2013 at 8:05:55 pm
What if upgrading OS isn't an option? I'm having the same problem with my renders. 5D source, exported to MXF RGB 1080p Avid 1:1 10 bits as well as QT Unc RGB 10 bits
