fcpx davinci resolve path problem?
COW Forums : DaVinci Resolve
theo peeters
on Jan 21, 2013 at 6:45:54 pm
I have fcp X 10.0.5 and da vinci resolve 9 lite.
I export from fcp a fcpXML to the desktop and I try to import the XML in resolve, but
I got the message :46 clips were not found Do you want to select another folder to search ?
If I say yes and try to find the xml on my desktop, I do not find it, nor on another place.
I was given an answer that : Its usually a database/default path fault.
Is it possible to solve the problem or do I have to forget about using davinci?
Joseph Owens
Re: fcpx davinci resolve path problem?
on Jan 21, 2013 at 11:14:53 pm
[theo peeters] "If I say yes and try to find the xml on my desktop, I do not find it, nor on another place."
Its looking for the media, not the XML. You should be able to navigate to your media folder within the Resolve browser. Where did FCPX put it?
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Simon Blackledge
on Jan 22, 2013 at 10:14:02 am
run fcp x and select a clip in the Events and Show in Finder.
Thats where the clips are. Unless you have multiple events.
Also depends if you transcoded and imported into fcpx events folder or just linked to the media and didnt transcode. In which case you need to point to the folder ORIG .movs are in as the ones n the Events folder will just be symbolic links ( alias's)
s
theo peeters
on Jan 22, 2013 at 11:05:18 am
Yes, thanks a lot, by showing it in finder, I found it and could bring it into davinci.
But there I now got the message that the GPU memory is full, try reducing the timeline resolution or the number of correctors.
What should I do, what is the GPU memory? (reducing the timeline resolution didn't change anything)
Simon Blackledge
on Jan 22, 2013 at 12:59:37 pm
Machine specs ?
Resolve version ?
s
theo peeters
on Jan 22, 2013 at 1:22:30 pm
MacPro 3.1 Mac os X 10.6.8 4 GB 800 MHz DDR2 FB-Dimm
Macintosh HD 247 GB available
Simon Blackledge
on Jan 22, 2013 at 2:35:16 pm
which Gfx cards ?
spec.. n ram for both.
s
theo peeters
on Jan 22, 2013 at 3:50:51 pm
Do you mean video card:
ATI Radeon HD 5770 type GPU
VRAM 1024 MB
Simon Blackledge
on Jan 23, 2013 at 10:24:57 am
Pretty sure ATI are not supported you need a CUDA card. Nvidia.
s
theo peeters
on Jan 23, 2013 at 11:01:59 am
Thanks Simon
Could you say what exactly I have to buy and any idea about the price?
(if I understand it well, I have to replace my current video card by the one you said?)
Dwaine Maggart
on Jan 23, 2013 at 7:05:57 pm
The ATI Radeon HD5770 card is supported by Resolve on Mac platforms. Your problem is probably related to the 1GB of VRAM that is on the card. For HD resolution work, 2GB would be better. If you are working with higher than HD resolution files, that will definitely be a problem with the 1GB of VRAM.
See the Resolve Mac Config guide on the BMD web site for supported cards on Mac.
Dwaine Maggart
Blackmagic Design DaVinci Support
theo peeters
on Jan 23, 2013 at 10:24:00 pm
This is what I found:
http://www.blackmagicdesign.com/media/4805315/Resolve_Mac_Config_Guide_2012...
page 15 :
The ATI Radeon HD 5770 is a standard graphics card with the 2010 and 2012 series of Mac Pro computers.
I have hd images 1920/1080
Shouldn't it work with my ati card?
Dwaine Maggart
on Jan 23, 2013 at 11:26:42 pm
We only recommend the HD5770 and GT120 cards be used as GUI display cards for Resolve.
That said, if you have HD files, those should load and work in Resolve with just the HD5770 card. If you did a bunch of crazy parallel node structures, you might exceed the 1GB VRAM capacity. But to just load the media with a single node on the Color page, yes, that should work fine with the HD5770 card.
If you are loading HD clips into the Media Pool, and you have the Resolve Timeline resolution set to HD, and you are getting the error message, my best guess would be it's an OS issue of some sort. Are you running in 64 bit mode? Resolve 9 and higher requires OS X to be in 64 bit mode. The default mode for OS X 10.6.8 is 32 bit mode. If you are in 32 bit mode, that is the problem.
Dwaine Maggart
theo peeters
on Jan 25, 2013 at 10:29:08 am
I downloaded Kernel Startup program to make it possible to choose to start up in 64 bit mode.
But still the same problem I am afraid.And I should be in 64 bit mode now (I tried it several times again)
If I see that I imported .mov in davinci, by using finder to find the media. It is not xml I imported I guess.I don't know if that has something to do with it (the xml I do not find using davince to search)
Cristobal Rey
on Nov 28, 2013 at 8:36:39 am
i guess i have the same problem "x items were not found" "do you want to select another folder to search?" i say yes but it does't give the chance to choose the folder where the media is, in an external hard drive...it just shows me the movies folder in my macbook....
i tried everything and no way..please help!!!
