Resolve 9.1- Missing Avid MXF Codecs in Deliver?
COW Forums : DaVinci Resolve
John Burkhart
on Jan 19, 2013 at 10:01:26 am
Hi Guys,
We seem to have lost most of the Avid MXF codecs in "deliver" in 9.1. All the Avid codecs are 1:1 only, which takes up a hell of a lot of space. I'd like to use resolve to output proxies in dnxhd 36, or other codecs that were available in 9.0 and below.
Is this an oversight? Or were these codecs removed permanently?
John Burkhart
Rohit Gupta
Re: Resolve 9.1- Missing Avid MXF Codecs in Deliver?
on Jan 19, 2013 at 3:55:36 pm
Hi John,
This is a bug which affects the Lite version only, and on the Mac platform only.
We hope to have a fix available soon.
Regards,
Rohit
Chris Kenny
on Jan 19, 2013 at 8:35:04 pm
Not seeing any DNxHD MXF options in Lite 9.1 on Windows 7 either.
Digital Workflow/Colorist, Nice Dissolve.
You should follow me on Twitter here. Or read our blog.
Sascha Haber
on Jan 19, 2013 at 9:22:55 pm
I also like to see some options for SD.
U
A slice of color...
Resolve 9.0.5 OSX 10.8.2
Colorist / Aerial footage producer
http://vimeo.com/saschahaber
Andrew Stone
on Jan 21, 2013 at 2:10:55 am
I see all the DNxHD MXF codec settings on Windows 7 in Resolve 9.1
-Andrew
Chris Kenny
on Jan 21, 2013 at 7:44:13 am
[Andrew Stone] "I see all the DNxHD MXF codec settings on Windows 7 in Resolve 9.1"
Full, or lite? I generally test new versions on one of our dailies transcoding machines, which run lite, so I haven't installed the full version of 9.1 yet.
Andrew Stone
on Jan 21, 2013 at 3:59:00 pm
The lite version. 14 presets come up for DNxHD: 720p 8 bit to 1080p 444.
-Andrew
Chris Kenny
on Jan 21, 2013 at 5:53:13 pm
[Andrew Stone] "The lite version. 14 presets come up for DNxHD: 720p 8 bit to 1080p 444."
Uninstalled, reinstalled, and now they show up. Weird.
Nodari Nozadze
on Jan 22, 2013 at 9:36:07 am
I tried reinstalling but DNxHD 36 deliver option is still not there, is there a workaround, I was looking for 9.0 version but can't find it anywhere, does blackmagic give us an option to download an older version of resolve lite? maybe this problem won't be an issue in an older versions.
jake blackstone
on Jan 23, 2013 at 2:36:23 am
For some reason BM keeps old versions of Resolve under "Drivers" software. It's been this way forever. Can't you guys at some point take care of it?
Ted Weinbaum
on Jan 22, 2013 at 9:59:31 pm
Rohit, I'm on a mac using resolve 9.1, and I find I can't even link up with any MXF media so as to load an aaf, or get the media to the media pool. When I open the folder within Resolve, it appears empty instead of seeing the MXF36 files that are stored there (which wasn't a problem with 8). Is this also part of the bug you mentioned for which a fix is being made?
Ted
John Burkhart
on Jan 24, 2013 at 9:54:19 am
Yes, it looks like you can't read MXF's from the missing codecs either.
John Burkhart
http://ditspot.com
