fcp x export xml to davinci resolve; path problem?
COW Forums : DaVinci Resolve
theo peeters
on Jan 17, 2013 at 2:45:37 pm
I have fcp X 10.0.5 and da vinci resolve 9 lite.
I export from fcp a fcpXML to the desktop and I try to import the XML in resolve, but
I got the message :46 clips were not found Do you want to select another folder to search ?
If I say yes and try to find the xml on my desktop, I do not find it, nor on another place.
I was given an answer that : Its usually a database/default path fault.
Is it and if so, how do I solve the problem?
theo peeters
Re: fcp x export xml to davinci resolve; path problem?
on Jan 21, 2013 at 6:42:27 pm
Is there no solution for the problem?
