importing titels and video mix downs from avid
COW Forums : DaVinci Resolve
Martin Halm
on Jan 13, 2013 at 9:24:44 am
i have an avid MC 6 project using only AMA files (canon 5d)and some titels and background clips made in avid (DNxHD 185)
importing the AAF in resolve works fine - i gave the original files a tape name in avid and the same as reel name in resolve - so it finds the corresponding files.
but there are some FX clips (video mixdown to DNxHD), titles and simple background clips (like fade to white) how can i link to these in resolve, so i have a complete final timeline to grade?
thanks - martin
iMac 2.93 GHz Intel Core Duo
Resolve Lite 9.03
Avid MC 6
Bouke Vahl
Re: importing titels and video mix downs from avid
on Jan 13, 2013 at 9:47:07 am
You don't
Normally before going to CC you strip all effects.
Makes sense, if you have a fade to white on a clip that needs tons of cc, you won't end up with white...
hth,
Bouke
http://www.videotoolshed.com/
smart tools for video pros
Pat Horridge
on Jan 14, 2013 at 9:45:37 am
If you need to pass a videomixdown or similar. Then in Avid export it as a file and either re-import or AMA it.
But as said the grade should be Raw elements not titles or effects.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Martin Halm
on Jan 15, 2013 at 1:30:13 pm
thanks bouke and pat,
you are so write - does not make sense, what i intended to do.
but i like the tip to mixdown, export, reimport for AMA link.
cheers - martin
Resolve Lite 9.03
Avid MC 6
