Conform page - No image of the timeline on the recorder side.
COW Forums : DaVinci Resolve
Ronen Pestes
on Jan 10, 2013 at 8:35:19 pm
I am having this issue when I don't see any image of the time line on the Conform page - recorder side.
See attached image.
I have tested few projects and timelines, also enabling disabling video tracks with no change.
Is it something that I just didn't enable the right check-box in the setting page?
The Color page works fine.
MacPro 3.1
Resolve 9.0.4 with Desktop Video 9.6.9
Ronen
Peter Chamberlain
Re: Conform page - No image of the timeline on the recorder side.
on Jan 11, 2013 at 1:54:24 am
Um.... if you select play then stop does the image return?
Ronen Pestes
on Jan 11, 2013 at 4:21:32 pm
Yes!
Is that a 'normal' behavior? I need to push the play each time I am loading a sequence and offline clip. (both sides will be dark until I hit the play)
Thank you.
Ronen
jake blackstone
on Jan 12, 2013 at 8:03:46 am
Yep, that's the way it works. You must push play to see it, but not every time:-) Pretty annoying...
