Connection for HP Dreamcolor monitor
COW Forums : DaVinci Resolve
ergin ozturk
on Dec 17, 2012 at 12:24:54 pm
I've just purchased HP Dreamcolor as grading monitor for my DavinciResolve suit.
Although i read lots of article & forums i could not find the clear answer for the connection yet:
I have MacPro with following cards;
1-Nvidea Quadro 4000 (for GPU) - (output: Displayport)
2-Nvidia geforce gt 120 (fori GUI)
3-Decklink HD Extreme 3D - (outputs: HD-SDI and HDMI output)
4-(external) HDLink Pro with DVI-D (outputs: DVI-D) - for my ex grading monitor AppleCinema display
my question is;
to use Dreamcolor's 10 bit feature what kind of connection should i use?
a-Quadro4000 DisplayPort ->Dreamcolor Display port ?
b-Decklink HD Extreme HDMI ->Dreamcolor HDMI ?
c-HDLink Pro with DVI-D -> Dreamcolor DVI?
d-or any other?
thanks in advance.
//ergin
Paul Jay
Re: Connection for HP Dreamcolor monitor
on Dec 17, 2012 at 5:50:11 pm
Hdp2 or hdlink pro
HdSdi from decklink
Robert Houllahan
on Dec 17, 2012 at 8:13:03 pm
I would recommend the AJA converter as it has modes to use deep color on the HP and is less expensive. Unfortunately the HD-Link Pro Display Port has a problem where it distorts 3D LUTs that are loaded into it making it practically unusable until BMD fixes the problem.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.com
MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Juan Salvo
on Dec 17, 2012 at 11:02:23 pm
Or you could just not use a lut on it.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Eric Sternberger
on Dec 18, 2012 at 2:04:48 pm
when you have to buy the aja Hi 5 for connections, the dreamcolor is in the same price-range as a FSI-Monitor, which is a "real" monitor. Is the color-reproduction on the HP so much better to justify spending my money on it anyway?
I think a lot of you guys have seen both. so how do they compare? (color-wise)
Eric Sternberger
on Dec 18, 2012 at 2:31:41 pm
Juan Salvo
on Dec 19, 2012 at 5:49:20 am
[Eric Sternberger] "he dreamcolor is in the same price-range as a FSI-Monitor, which is a "real" monitor. "
This is a really good point. The dreamcolors are also notoriously flaky. And just frankly not a very good choice.
Robert Houllahan
on Dec 18, 2012 at 10:35:06 pm
I tried to use the Decklink-Pro Display Port without a LUT and either with connection to HDMI or as a SDI pass-through it changes the picture... so until they fix it I consider it a $700.00 paperweight.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
Javier Martos Valladares
on Jan 16, 2013 at 9:44:19 pm
The dreamcolor monitor entine needs a true RGB 4:4:4 signal vía display port so it's a bit dificult to configure.
Allan Tepper has a lot of info about that issue in provideo coaliton web.
I was planning on buying one but maybe an FSI is more compatible, but the 10bit model FSI is more expensive.
