Rendering Using Source Clip Prefix, Suffix, Digits
COW Forums : DaVinci Resolve
Chris Martin
on Dec 14, 2012 at 4:50:49 pm
I notice when I render out preserving source clip naming that Resolve will still add a decimal and then a digit count even when format is set to quicktimes. The end result for me, in particular with Alexa footage where we're rendering our selects for final conform, is that I have to remove the digits after the render from the clip name. Number of digits is greyed out once you select "Use Prefix, Suffix No of Digits From Source" but these digits added by Resolve are not in the original source file name.
Can anyone tell me how to avoid this (yes I've read through the manual and searched the forum).
Chris
Sascha Haber
Re: Rendering Using Source Clip Prefix, Suffix, Digits
on Dec 14, 2012 at 7:01:51 pm
And you are sure to render out the same clip only once ?
I had this when splitting it ...
A slice of color...
Resolve 9.0.4 OSX 10.8.2
Colorist / Aerial footage producer
http://vimeo.com/saschahaber
