pluraleyes files no sound in resolve
COW Forums : DaVinci Resolve
Martin Halm
on Nov 30, 2012 at 10:37:01 pm
hi there,
i wanted to test pluraleyes 3 today for syncing canon 5D MkII H264 files with sound being recorded external without TC. syncing the files in pluraleyes went pretty smooth. and much faster than the old version.
i exported the resulting MOVs (including the new audio) to a bin. surprisingly resolve does not play audio of these files.
in the media pool the movie icons show the audio sign and in the audio window you see tracks 1 and 2 highlighted. i guess this means, resolve "sees", that the MOVs contain the two tracks of audio. but: no signal there - abolute silence
playing back the same files in apple quicktime player: no problem, picture AND sound OK.
when i add the original MOVs into the media pool everything is fine. resolve sees and plays the sound of the internally recorded audio.
right now i can forget about my "perfect" workflow i intended to go:
1 - autosync video/audio in pluraleys
2 - import resulting synced MOVs in resolve
3 - 1 light color correction and burnins in resolve
4 - export to avid DNxHD 120 for offline
5 - edit in media composer
6 - export AAF to resolve
7 - import AAF
8 - link to synced MOVs
9 - grade and finish in resolve
anybody has an idea? maybe pluraleyes creates none-standard files??
iMac 2.93 GHz Intel Core Duo
Resolve Lite 9.03
Avid MC 6
Michael Phillips
Re: pluraleyes files no sound in resolve
on Dec 2, 2012 at 3:31:55 pm
Strange that it doesn't see/hear the sound after the sync process. Perhaps in the interim, change the steps around a little:
Grade first, create QuickTime wrapped DNxHD (not MXF wrapped)
Sync in Pluraleyes
Either fast import or AMA consolidate which both should be just the time it takes to do a copy.
Michael
Martin Halm
on Dec 2, 2012 at 6:28:13 pm
hey michael,
i just got answer today from RED GIANT support. they are aware of the problem and will see into it.
thanks for your tip - this might work.
martin
Resolve Lite 9.03
Avid MC 6
