imac with no thunderbolt & Blackmagic HD Link Pro
COW Forums : DaVinci Resolve
Ivan Castell
on Nov 25, 2012 at 11:32:10 am
I'm looking for a 10-bit monitoring solution for color correction and Davinci Resolve. I have a late 2009 imac (no thunderbolt, no usb 3.0, just mini displayport). I was thinking about this workflow with blackmagic products:
1) Mini DP to HDMI (it should be 10-bit).
2) Blackmagic HDMI to SDI
3) HD Link Pro (to the monitor via HDMI or DP)
Will this work? I don't know if this is a 10-bit workflow.
I'll be using this with a Dell u2410. I know it's better to have a real broadcast monitor in the end of the chain. The dell is listed as a 10-bit panel, so it's better than nothing.
I can get the old Matrox MXO and just connect it via a DP to DVI cable, but I've read around here that it's a 8-bit solution and it's and old (and unsupported) product, but it'll work. I just want a broadcast signal that I can trust with some accuracy, for a low-budget documentary (shot on 5D/550D) i'll be grading and I'll like to work with Davinci resolve (that's why I'll like a Blackmagic product).
Thanks.
Indie filmmaker
http://ivancastell.org
Robert Houllahan
Re: imac with no thunderbolt & Blackmagic HD Link Pro
on Nov 25, 2012 at 3:47:03 pm
All GFX card outputs from OSX are 8-bit and Resolve will not send full video to a GPU attached monitor only out to a SDI card through whatever interface the video interface is on, i.e. Thunderbolt or PCIe.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.com
MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Ivan Castell
on Nov 25, 2012 at 5:03:29 pm
Thanks for the answer.
So, even if these connections works, the OSX system can't output to 10-bit from the imac card, only 8-bit, right?
Indie filmmaker
Robert Houllahan
on Nov 25, 2012 at 5:50:34 pm
Yes even if the Display Port cold output video (i.e. FCP second monitor as video) OSX is 8-bit only and that output would be under the OSX color management and may be highly inaccurate.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
Ivan Castell
on Nov 25, 2012 at 6:15:01 pm
I guess I'll have to deal with the 8-bit output on the iMac.
Thanks for the info Robert!
Indie filmmaker
Dwaine Maggart
on Nov 26, 2012 at 5:13:39 pm
A larger problem is that Resolve will not run on a 2009 iMac due to it not having a supported GPU. You need at least a 2011 iMac for Resolve. Details are in the Mac Resolve Config guide on the BMD web site in the DaVinci Resolve support area.
Dwaine Maggart
Blackmagic Design DaVinci Support
Ivan Castell
on Nov 26, 2012 at 10:11:03 pm
Hi Dwaine,
I didn't know that. I'm new to Davinci Resolve (I use Apple Color). I have a warning message when launching Resolve Lite about the hardware GPU not being capable of realtime performance, but the app launch and I can use it. I have an ATI HD 4850.
Ok, so even if I attach from the DP to the HDLink Pro (via the HDMI to SDI miniconverter), there's no way of getting a broadcast signal (even a 8-bit) from the displayport on my imac with BM products? Damn, I can't then use Resolve.
Indie filmmaker
