Pasting saved RED grades not replacing existing Camera Raw clip settings?
COW Forums : DaVinci Resolve
Mel Matsuoka
on Nov 13, 2012 at 9:36:53 pm
I'm on 9.0.3, and trying to wrap my head around why it is when I save a RED based grade––for which I've tweaked the color temp/tint metadata––then paste that grade onto a new clip, that the tweaked metadata settings in the saved grade do not replace the metadata settings on the clip I paste it on?
I tried saving the original grade with the "Save with Version" option checked and unchecked, and I also made sure that the "Copy Grade: Preserve Source Settings" option is disabled in the Gallery, but this seems to have no effect when recalling the grade on a new clip. Everything else from the grade pastes in fine, except for the altered RED metadata settings.
This is proving to be a total nightmare for me right now, as I'm trying to ColorTrace a feature length film that was originally conformed into Resolve at the wrong framerate, and I have to constantly switch back and forth between projects to manually ascertain the original camera raw metadata settings for each clip.
Any ideas?
Joseph Owens
Re: Pasting saved RED grades not replacing existing Camera Raw clip settings?
on Nov 14, 2012 at 12:02:55 am
Is this the same topic?
http://forums.creativecow.net/thread/277/21675
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Mel Matsuoka
on Nov 14, 2012 at 12:16:59 am
Jake is basically asking the inverse of what I'm looking for. In my case, I want the modified R3D metadata in the saved grade to completely overwrite whatever original R3D metadata is on clip I'm pasting the grade to.
My problem is that I cant get the saved grade to do that. Oddly enough, it's basically behaving in the exact manner that Jake wants.
jake blackstone
on Nov 14, 2012 at 4:54:46 am
Yes, it does work the way I had asked. You need to follow Peter's suggestion and uncheck the "Copy Grade: Preserve Source Settings" option in the PREFERENCES:-) I believe, that unchecking "Copy Grade: Preserve Source Settings" option it in the gallery affects only that event.
jake blackstone
on Nov 15, 2012 at 7:36:12 am
I checked both ways of setting "Copy Grade: Preserve Source Settings" and they both work exactly the same.
