B/W render
COW Forums : DaVinci Resolve
bristol cruz
B/W render
on Nov 2, 2012 at 12:46:13 pm
I work on a black/white project with hard contrast and with a lot of channel mixer adjustments.
This is mainly for TV, but I also want to make a web master.
Im adjusting internally full range (0-1023), my monitor is set up as 709 and Im monitoring in normal range. This makes the commercials look like it should on my monitor and for TV.
Usually I render full range (RGB) for web versions but I see that the blacks will be super deep as the tonal range is a bit deeper on this project. The black between 0 - 40 IRE will be merged in a way.
How do you deal with this? I can render 709 and do a black restoration in Sorenson but Im not sure if that is the best approach.
© 2018 All Rights Reserved
