using stills as background for key
COW Forums : DaVinci Resolve
Martin Halm
on Oct 26, 2012 at 11:55:13 am
i want to use a still (tif) as background for a greenscreen key.
thought i just place it in V1 and put my footage above it in V2 and then key V2..
but how do i change the background clip duration from single frame to an x-amount of time? could not find a way during import, nor in media pool or conform page.
sorry for such a basic question - cheers
Paul Provost
Re: using stills as background for key
on Oct 26, 2012 at 3:23:53 pm
No still images or freeze frames in resolve yet
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
Martin Halm
on Oct 26, 2012 at 9:47:20 pm
oops! who would have thought that?
thanks anyway!
Knut Jansohn
on Oct 30, 2012 at 10:19:32 am
Simply append a number at the end of filename. So resolve will recognise the file as a part of an image sequence :)
K.
Rohit Gupta
on Oct 30, 2012 at 3:32:39 pm
You should add the tif file to media pool, and then drop it in timeline, change the speed to 0fps, and then you can stretch it out.
If you are not on 9.0.3, you will need to rename the file to add a number at the end (before the extension).
Rohit
Paul Provost
on Oct 30, 2012 at 4:51:36 pm
Rohit - is this a new option? how about stills in an fcp xml? will it work with jpeg too?
