Audio Auto Sync - Is it possible to slip audio after auto syncing?
COW Forums : DaVinci Resolve
Craig Harris
on Oct 17, 2012 at 2:54:42 pm
The auto sync works great!
However, the timecode from audio isn't always bang-on with the camera. Usually I see it drift 1-3 frames throughout the day.
Is it possible to auto sync and then slip the audio to match the sticks?
Anish Prithviraj
Re: Audio Auto Sync - Is it possible to slip audio after auto syncing?
on Oct 18, 2012 at 3:49:21 am
Hi Craig,
You can slip audio forward and back a frame by using the Option/Alt + , and Option/Alt + . shortcuts (these can be found in the Edit menu).
Alternatively, you can Right click on the audio/speaker icon on the bottom left of the conform page thumbnail and edit the Audio Sync timecode.
Anish
Christian Hart
on Dec 3, 2012 at 9:01:34 pm
Hi there,
just to hop on the end of this thread with a related issue
I'm making dailies with LUTs and and a burn in & syncing audio within Davinci Resolve Lite 9.0.3
In the case that audio is out of sync (camera/magic slate issue) i have tried slipping the audio manually first in the timeline & all seems fine.
But then when i add those timelines to the render queue & export them - the audio in the resulting clips is off as if i had not tweaked the sync manually to fix them.
Quite frustrating. If anyone knows some schoolboy error i may be making i'd love to hear some ideas.
Best
