1D vs 3D LUT 'looks' packages
COW Forums : DaVinci Resolve
jim bachalo
on Oct 3, 2012 at 3:30:45 pm
I see a lot or predefined 'looks' packages mentioning they use 3D LUTs, instead of just 1D LUTS.
Can someone in a nutshell explain why this would result in much higher quality result?
Local is the new global
jim bachalo
Re: 1D vs 3D LUT 'looks' packages
on Oct 3, 2012 at 4:41:02 pm
Answering my own question ;)
http://techblog.cineform.com/?p=2798
'* note: Using a lower resolution LUT, does not impact the quality of the video it is being applied, the resolution of the LUT only impacts the accuracy of the larger full color cube it is modeling. I’ve seen a 8x8x8 bleach bypass, look as good as 64x64x64 equivalent, so 64^3 LUTs are often overkill.'
