Resolve 9 lite save to RMD
COW Forums : DaVinci Resolve
Adasa Cookey
on Oct 2, 2012 at 6:58:53 pm
Hello All,
Please Help. is it possible to grade RED footage in Resolve 9 lite and save to RMD like is possible in Redcine X?
Peter Chamberlain
Re: Resolve 9 lite save to RMD
on Oct 3, 2012 at 1:30:33 am
As an acquisition format the r3d's can be decoded and debayered in Resolve where we use 32bit floating point processing. If you have made grades on set and saved those in the RMD, Resolve will read those when the files are placed into the Media Pool but once there, the range and control of the grade is significantly broader in Resolve, and many parameters that do not map directly, so there is no modification of the RMD to add Resolve corrections.
You can finish in Resolve at the 32bit float and when its time to deliver make a EXR or Rec709 or P3 or what ever deliverable you need.
© 2018 All Rights Reserved
