Flares first or grading first? (workflow question)
COW Forums : DaVinci Resolve
Enno Jacobsen
on Oct 1, 2012 at 7:07:35 pm
Wondering about the best workflow...
(1) Correcting the material in Resolve to a basic, fairly neutral and technically "correct" state, then add optical flares in AE. And in a third step finally bring it back to Resolve to set the look.
(2) Add the flares first, then migrate to Resolve to correct and set the look
(3) Correct and set the look first and then move over to AE to add optical flares.
Any advice in this matter? What would be the right order?
Sascha Haber
Re: Flares first or grading first? (workflow question)
on Oct 1, 2012 at 7:17:24 pm
1
A slice of color...
Resolve 9.01 OSX 10.8.2
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Enno Jacobsen
on Oct 1, 2012 at 8:52:57 pm
Thanks Sascha. Will do that.
Second time you helped me out with an answer already. You da man. Thank you.
Joseph Owens
on Oct 1, 2012 at 9:01:23 pm
[Enno Jacobsen] "(1) Correcting the material in Resolve to a basic, fairly neutral and technically "correct" state, then add optical flares in AE. And in a third step finally bring it back to Resolve to set the look."
Can the flares be exported as a Resolve-compatible codec with alpha channel? In that case, you could bring the layers into Resolve and grade/blend in context.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Dan Moran
on Oct 1, 2012 at 9:12:45 pm
Best way to do it is do a rough flares pass first with them in roughly the right place and intensity.
Render on black
Put them on v2 in resolve and use add blending mode
Grade away happily
Turn off the flares and render
Go back to AE and refine.
Works a treat and I used this workflow on the intro for this show :
Dan Moran
Colourist
Smoke & Mirrors: London
http://www.danmorancolor.com/blog
Juan Salvo
on Oct 2, 2012 at 12:13:04 am
Or you could do in the node tree now.
Resolve 9 EXT...fill? from Juan Salvo on Vimeo.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
dermot shane
on Oct 2, 2012 at 1:43:36 pm
Juan's tutorial is great....
still this is one are where Mystika, Pablo & DS shine, mainly due to being able to modify the effect's values, track & mask the generator point.. it's good to see Resolve's tools take a substaintial step up
My answer would be to do it interactivly, all at the same time, but i don't use Resolve, and this is the reason why ;-)
OFX host in Resolve would be a big help for sure in this scenairo
d
