AAF Conform Problems
COW Forums : DaVinci Resolve
Swen Linde
on Sep 26, 2012 at 10:32:30 am
Hi all,
we are in big trouble opening aaf Files from Avid Medicomposer 6.0 in Resolve 9.0.
Nearly 90% of the shots are not recognized. The AAF is exported with no media inside.
The following message appears after trying to link to the imported Alexa QT ProRes 4444 Files.
"Non-File SourceMob is detected and ignored".
EDL Conform of the same Sequence works fine.
Has anybody expirience with this issue.
I also tried this aaf in Scratch which worked fine.
Thanks for your help.
Best Regards.
Swen
Craig Harris
Re: AAF Conform Problems
on Sep 26, 2012 at 5:34:25 pm
Hello there,
You need to commit all multi-cam edits in AVID before you export the AAF.
Craig
Craig Harris
on Sep 26, 2012 at 5:47:08 pm
How is Resolve set up for reading your Reel IDs?
What is your source footage?
Swen Linde
on Sep 27, 2012 at 12:23:14 pm
Thanks Craig, for oyur quick response.
The Footage is Alexa Log-C and the Reel ID will be taken from the embedded one in the Source Clip. I will check if the Multi Cams are committed.
Swen
Rohit Gupta
on Sep 27, 2012 at 1:16:30 pm
Can you send us the AAF at davincihelp (at) blackmagicdesign.com?
Rohit
Swen Linde
on Sep 27, 2012 at 1:48:24 pm
Hi Rohit hi Craig,
the aaf is working now. The editorial did not commit the multicams and I forgot to check this. Thanks Craig. Rohit i will send the aaf to the davinci support. It´s conforming but has a lot of error messages as mentioned before. "Non-File SourceMob is detected and ignored".
It will be interessting to hear what this is saying us.
With best regards
Swen
Craig Harris
on Sep 27, 2012 at 8:49:31 pm
DaVinci won't read all the AVID effects. That is probably why you are getting the error messages.
Craig
