Lut highlights
COW Forums : DaVinci Resolve
stig olsen
Lut highlights
on Sep 18, 2012 at 5:20:09 pm
Hi, When working on r3d I do my main exposure adjustments prior to the LUT. Sometimes I need a good key for adjusting highlights and therefore working after the LUT. Some adjustments (like highlight adjustments) will not work properly after the LUT so Im getting stuck with a bad key. How do you deal with that?
Sascha Haber
Re: Lut highlights
on Sep 18, 2012 at 7:54:29 pm
Using a second input or a parallel node
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
stig olsen
Re: Lut highlights
on Sep 18, 2012 at 8:30:20 pm
It does not help because the key need an input from after the LUT.
stig olsen
Re: Lut highlights
on Sep 19, 2012 at 10:37:33 am
Anyone?
I need to make a key from a node after the lut but to adjust the keyed part properly I need to do have access to the source or a node prior to the LUT.
Stig
Chris Martin
Re: Lut highlights
on Sep 19, 2012 at 5:33:36 pm
What is the LUT for?
Ola Haldor Voll
Re: Lut highlights
on Sep 20, 2012 at 6:52:06 am
Try using a Parallel node. You can select what node is the source for the node, or even the main video source as well.
Rohit Gupta
Re: Lut highlights
on Sep 20, 2012 at 6:59:35 am
Or you can just add a node, feed the input from the source, and only use this node to output a key. This is assuming you don't want to mix back any of the original image. If you need to mix back any of the original image, you can use a layer mixer as well.
stig olsen
Re: Lut highlights
on Sep 20, 2012 at 7:34:44 am
Hi, I did not explain myself good enough. The key need its source from a node after the LUT (to have s clean key). To adjust this key I need the source from the node before the LUT. These sources need to be connected somehow.
stig olsen
Re: Lut highlights
on Sep 20, 2012 at 9:00:06 am
It did work by doing this:
- Create a corrector node after the LUT to have a clean key
- Create a parallel node, but change the input to a node prior to the LUT
- Feed the key into the parallel node
- Invert the key or add an outside node to adjust.
This way it will give a clean key (made from after the LUT) and all the corrections will affect the data prior to the LUT but feed it back later in the chain.
Stig
