Automatic adjustments to clips from same take? Can i turn this off?
COW Forums : DaVinci Resolve
Neil Goodman
on Sep 14, 2012 at 2:16:51 am
I imported an AAF from Media Composer.
Alot of the clips were subclipped out from the same takes so when I go to color page and start to do a primary on the first clip, the rest of the clips on the timeline from that take are changing too. Can i turn this behavior off?
Neil Goodman: Editor of New Media Production - NBC/Universal
Joseph Owens
Re: Automatic adjustments to clips from same take? Can i turn this off?
on Sep 14, 2012 at 2:41:08 am
[Neil Goodman] ". Can i turn this behavior off?"
Yes its an "unlink" behaviour, or create local/remote versions.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Neil Goodman
on Sep 14, 2012 at 4:01:24 am
Pardon my ignorance, finally coming over from Color..where is this option to unlink? I odnt see it in a menu or anything.
I see how to make a version 2 for each clip individually which seems to do the trick but is there a way i can do that for every clip on the timeline at once?
Also will this technique of making new versions, effect my ability to re-link in media composer later for finishing?
Pepijn Klijs
on Sep 14, 2012 at 5:58:52 am
The option is still there, but I just found out that they've changed the name... Couldnt find it either!
Anyway, it's still under the menu when you rightclick a thumbnail in the timeline and it's called: use local grades. But this will delete any grades you might have done. 'copy remote grades to local' will keep the grades but break the linking.
Good luck
Pepo
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl
Christopher Adams
on Sep 14, 2012 at 10:01:17 am
Haha I was showing someone that same problem yesterday and could not find it either...thanks!
Chris Martin
on Sep 14, 2012 at 3:27:23 pm
Using versions is a bit more house keeping but gives you way more options within a grading session.
Neil Goodman
on Sep 14, 2012 at 4:02:11 pm
great, thanks everyone!
so messing with all these versions wont efect my ability to go back to avid ?
