Unexpected color flashes on export frames
COW Forums : DaVinci Resolve
Stephen Kennedy
on Sep 12, 2012 at 6:48:42 pm
First time actually rendering out of Davinci Reolve 9 (Lite) and I'm getting all these strange color flashes on quite a few frames here and there.
Example: frame
Specs I'm using:
Macbook Pro 17"
2.5 Ghz i7
16 GB 1333 Mhz DDR3 RAM
Lion 10.7.4
AMD Radeon HD 6770M 1024 MB
Is this a hardware issue?
Anyone else experienced this before? And know how to fix it?!
Eric Johnson
Re: Unexpected color flashes on export frames
on Sep 13, 2012 at 8:30:18 pm
That looks like potential clipping.... If not, I believe I read on here a while back about throttling down the render speed (you can do that on the screen you set your renders on) and that stuff going away.
Gino Amadori
on Sep 14, 2012 at 6:12:52 am
Hi Stephan, I had the same problem with the same computer. It is the AMD video card and the Lion version you have. To correct this I upgraded to Mountain Lion and the problem was solved.
Hope this works for you too
Good luck
Gino Amadori
Freelance Editor / Colorist
Google: ginoamadori@gmail.com
Skype: ginoamadori
Cell: +(51) 9930-37686
Lima - Peru
Stephen Kennedy
on Sep 14, 2012 at 6:16:43 am
I posted over on Blackmagic's own forum too and someone recommended the same thing, so I set about downloading and installing Mountain Lion (which was no mean feat down here in the jungle of Ecuador I can tell you).
It seems to have completely solved the problem.
Thanks for your responses.
Cheers,
S
