Resolve Running Low On Memory
COW Forums : DaVinci Resolve
Dave Williams
on Sep 12, 2012 at 2:57:18 am
Hello
Lately I have been experiencing a warning of "Resolve is running low on memory" If I say Ok enough times it eventually crashes. I use to be able to load 2 or 3 hours of footage with some rough grades and no problem.
I have now experienced this with a 60 second spot with only the selects imported in. I am now experiencing it on a 48 minute show with only the selects which are cut to fit. The show is all prores 422. I am running 8.2 and cannot bump up to 9 yet. I have 2 Quadro 4000's and a red rocket card. Running on a 2011 Mac pro with 24 gbs of ram.
Any suggestions or any thing that would help would be appreciated.
Juan Salvo
Re: Resolve Running Low On Memory
on Sep 12, 2012 at 3:01:24 am
What os are you running? re you usi any other apps?
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Dave Williams
on Sep 12, 2012 at 3:04:27 am
Running 10.6.8 and there are no other apps running.
Teo Rižnar
on Sep 12, 2012 at 6:00:37 am
This error was common in V8 if you had a big project. for feature films if you didn't split reels/sequences in different projcets it was "out of memory" all the time. But in V9, I am handleing same big projects and even bigger ones and there is no more problems!
Are you running V8 or V9?
Color grade reel:
Cofounder of http://nuframe.si postproduction
Sascha Haber
Re: solve Running Low On Memory
on Sep 12, 2012 at 6:29:24 am
Do to the nature of Resolve being a 32 bit application, there is nothing you can do.
You need to get 9 to use more RAM
Or work in proxies if you raid allowed DPX playback
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
