Flat file workflow...
COW Forums : DaVinci Resolve
Gabriel Regalbuto
on Sep 11, 2012 at 5:30:38 am
I've had no luck getting a Premiere project into DaVinci. Here's the lowdown...
Its a multi-cam project. Multicam, Premiere, and xml don't mix. EDLs don't either - matched code notwithstanding.
Thinking I was super-clever, I brought my rendered file into Premiere, stacked it on top of the original edit, and added edits at every cut. I then deleted the original clips and exported an xml with only the video.
Brought it into DaVinci and voila! All my cuts are there perfect. Problem is, though the timeline lists 90 clips, and though I am working on clips, not the track, when I grade 1 clip, 89 others do the same thing.
Has to be simple, right?
Thanks in advance!
Margus Voll
Re: Flat file workflow...
on Sep 11, 2012 at 5:58:49 am
look up in manual batch copy or batch unlink.
this should help you on this one.
Margus
http://iconstudios.eu
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Pepijn Klijs
on Sep 11, 2012 at 6:29:55 am
Just my thought as well!
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl
Andrew Anderson
on Sep 11, 2012 at 7:59:24 am
find the option in settings tab V8 or conform option section in V9, page 81 of the manual
"Split source clips for pre-conform"
This is a better method for approaching a pre-conform..
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
Gabriel Regalbuto
on Sep 11, 2012 at 3:04:35 pm
Excellent. Thank you gentlemen!
FC7 CS5.5
MacPro 8x
5drive eSATA stripe
Joseph Mastantuono
on Sep 15, 2012 at 1:49:56 pm
All these workflows are clearly delineated in the manual. You could have saved yourself a lot of time if had just opened it.
Joseph Mastantuono
http://www.goodpost.net
Color Grading & Post Production Consulting
