Resolve 9 not importing Jpges
COW Forums : DaVinci Resolve
jeff walsh
on Sep 10, 2012 at 9:30:59 pm
I have a Final Cut sequence with a series of stills. When I export a xml and bring that into DaVinci the stills don't show up. Any ideas?
Thank you
jeff w.
http://www.vimeo.com/williamwalshj
Sascha Haber
Re: solve 9 not importing Jpges
on Sep 10, 2012 at 9:42:10 pm
It doesnt support stills
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Andrew Anderson
Re: Resolve 9 not importing Jpges
on Sep 11, 2012 at 1:45:52 am
As Sascha says, it wont suport stills !
work around,
convert your stills to mov in the same timeline codec, re-import that mov back into your FCP timeline replacing the stills and then create a new XML
or
convert jpegs to tiff, make sure you have a sequencial number of frames, ie
mytiff_001.tif
mytiff_002.tif
mytiff_003.tif
bring them back into your timeline in FCP replacing your jpegs and then create a new XML..
problem with this is no timecode with tiff so make sure you have separate sequences for each and are unique in naming.
That should do it ...
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
