How to replace conformed media with full lenght originals
COW Forums : DaVinci Resolve
Kaspar Kallas
on Sep 7, 2012 at 11:30:27 am
Hello
I started a project way back when and I was given a FCP project with media managed media. Now I got final cut of the project but this one is with full media.
Is there any way to replace the media on the version that I was working on to the full media and then add a another cut to retain my work?
It is documentary project where I use many versions on single clip because of cuts so colortarce will not work because it will copy only one version...
Thank You
Kaspar
Sascha Haber
Re: How to replace conformed media with full lenght originals
on Sep 7, 2012 at 12:04:48 pm
So you got consolidated movie files with timecode and reel ID intact ?
And now you got full clips ?
Then it should be easy.
If you one the other hand got total different media you should call the post producer and unleash hell ;)
Color Trace would be my next attempt , if that fails use the Create Thumbnail from Middle Frame and do it manually from a freshly created Gallery page.
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Kaspar Kallas
on Sep 7, 2012 at 12:11:40 pm
Hi
It seems version A (well there are no reel ID's but I should be able to do it by folders at minimum) but I don't know if the media is same names. Anyhow I will start to play with this tonight and will post my findings for anyone else that might find it helpful.
I think that colortrace could copy over all remote versions, that would be "muy" helpful.
Thank You
Kaspar
Sascha Haber
on Sep 7, 2012 at 1:08:20 pm
I muy muy agree :)
A slice of color...
RAID0 8TB
Extreme 3D+
