Davinci Resolve won't run on my 15" Macbook Pro Mid 2012 :(
COW Forums : DaVinci Resolve
Angel Mari Cañeda
on Sep 5, 2012 at 4:17:07 pm
I read somewhere that the Da Vinci Resolve 9 should run on a 1440x900 screen resolution. I'm using a Lion OSX 10.7.4
SPECS
1440 by 900
2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.6GHz) with 6MB L3 cache
8GB of 1600MHz DDR3 memory
750GB 5400-rpm hard drive
NVIDIA GeForce GT 650M with 1GB of GDDR5 memory
It won't even start :(
Ryan Holmes
Re: Davinci Resolve won't run on my 15" Macbook Pro Mid 2012 :(
on Sep 5, 2012 at 5:23:01 pm
[Angel Mari Cañeda] " Da Vinci Resolve 9 should run on a 1440x900 screen resolution"
I believe you need at least 1680x1050 resolution to run Resolve.
Taken from the system requirements PDF on the BlackMagic website:
The Resolve application is optimized for 2560x1440 screen resolution but will work with a MacBook Pro 15-inch Hi-Res (1680 x 1050) Widescreen Display and also 1920 x 1080 and higher screen resolutions. The Macbook Pro 15" with Retina display should be operated in 1920 x 1200 resolution.
Ryan Holmes
http://www.ryanholmes.me
vimeo.com/ryanholmes
Angel Mari Cañeda
on Sep 6, 2012 at 12:30:03 am
But I read somewhere here that davinci resolve 9 should be fine in a 1440x900 screen I just dont know how :/
Dwaine Maggart
on Sep 6, 2012 at 3:49:55 pm
Resolve requires a minimum screen resolution of 1680x1050. So for a (non-Retina) 15" MBP, you need to have the HiRes 1680x1050 display option. The standard 1440x900 resolution display will not work for Resolve.
The only possible exception to this is if you are using OSX 10.6.8. If you are, you can use the AppleDisplayScaleFactor command to squeeze the Resolve GUI onto the lower resolution display. This Cow thread provides the details: http://forums.creativecow.net/thread/277/2987#2987
Note that this capability was removed in Lion, so only works with Snow Leopard.
Dwaine Maggart
Blackmagic Design DaVinci Support
Angel Mari Cañeda
on Sep 6, 2012 at 11:50:33 pm
Thanks man. So I seriously need to downgrade to Snow Leopard if I want to make this work huh? anyway. Thanks so much! :)
Sascha Haber
on Sep 7, 2012 at 12:01:25 pm
What about those resolution changer tools ?
And good look going to SL.
Took me a whole day how to figure it out.
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Philip Hendel
on May 26, 2018 at 11:46:55 pm
Hi
I am wondering if there is still a possible way to get a DaVinci Lite version that was designed to run on OSX 10.6.8
I am running the entire FCP7 Studio & LogicPro9 suite on a 2008 MacbookPro 17" with two 23" external Apple monitors and would like to keep everything running with this OSX on the same SSD.
I have tried to get an old version from BlackMagic that would run on OSX 10.6.8, but have been told that it is not longer available from them,
Any help would be deeply appreciated,
Thank you,
Philip Hendel
Marc Wielage
on May 28, 2018 at 5:40:21 am
[Philip Hendel] "I am wondering if there is still a possible way to get a DaVinci Lite version that was designed to run on OSX 10.6.8"
Man, I wouldn't even try. It's just too old at this point. Find a way to get a newer machine -- they exist, and some are fairly affordable.
Look at it this way: 10 years ago, it cost more than $100K to run a fairly minimal version of Resolve.
Philip Hendel
on May 29, 2018 at 10:38:55 am
Thank you for responding:
Actually for me, the main issue is not hardware, it is the staying on OSX 10.6.8
Currently I am running the FCP7 Studio suite + LogicPro9 on this OSX without any glitches or problems.
If possible I would like to stay this way (ie glitch&problem-"free"). For coloring, Color 1.5 works very well.
I would however like to add DaVinci lite (the OSX 10.6.8 version) to my package and not have to go through, any delay causing software problems
Thank you again,
Philip
Michael Gissing
on May 30, 2018 at 2:13:11 am
[Philip Hendel]"I would however like to add DaVinci lite (the OSX 10.6.8 version) to my package and not have to go through, any delay causing software problems"
Resolve has moved a long way from a compatible Snow Leopard version. You would be better off with a dual boot partition and a more up to date OS to run Resolve. If you need to stay snow leopard for FCP7 (which is a good idea), then I wouldn't consider running Resolve on your hardware & software.
